40:60 front/rear split
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Siena
Post by Siena » Mon Mar 31, 2008 8:25 am
S4 AND RS4 are the same bias.
ZeroK66
Post by ZeroK66 » Mon Mar 31, 2008 11:00 am
I was absolutely sure the RS4 box/diff could split 25/75 eitherway vs 66:33 on the S4. Strange, oh well.
Soupie69uk
Post by Soupie69uk » Mon Mar 31, 2008 11:04 am
I am in the process of getting a couple of washers made up to make the ratio 4:1 on my car (20% to 80%).
I will keep you guys updated.
kies4
Post by kies4 » Mon Mar 31, 2008 2:34 pm
Soupie can u let me know where and what I have an rs4 diff to sort at the moment would love it sorted before it goes back in.
S4 Crazy Horse. Ringsticker & MRC black magic.
Soupie69uk
Post by Soupie69uk » Mon Mar 31, 2008 2:58 pm
You just need to replace 2 washers in the front torsen that is in the gearbox.
The early cars its easy to take the torsen to bits as its 2 piece and is held together with screws. The later cars have a 1 pc torsen and pins hold it together.
Both types use different size washers.
There is some info.
http://torsen.com/fsae/012000_washer.htm
kies4
Post by kies4 » Mon Mar 31, 2008 3:20 pm
cheers Soupie
tdiquattro
Post by tdiquattro » Mon Mar 31, 2008 5:22 pm
So which washers is it that you are changing, the link shows 7 washers?
Thanks,
Nige'
2000 silver S4 Saloon
Soupie69uk
Post by Soupie69uk » Mon Mar 31, 2008 10:14 pm
The two outside ones.
Here are some pics of a 2 pc one.
dummi
Post by dummi » Tue Apr 01, 2008 12:00 am
cool nice work :thumbsup:
Soupie69uk
Post by Soupie69uk » Tue Apr 01, 2008 12:01 am
I have not done it yet. Those are pics I have fund on the net.
I am just getting the washers and will do it after I have finished my uni work.
team_soy
Post by team_soy » Tue Apr 01, 2008 2:11 am
in for this...because i have tried contacting the guy who found out about this and he was saying that his washers will not work with the s4
DavidT
Post by DavidT » Wed Apr 02, 2008 7:13 pm
Am I right in saying this mod does not affect the fron/trear torque split (which stays 50:50) it just affects the bias the diff can transfer when the wheels on one axle spin ?
I would like to try a car with the mod done for sure but I think the S4 4wd system works very well as standard.
dummi
Post by dummi » Wed Apr 02, 2008 9:17 pm
the torque split is what is 2:1 max standard s4 , if a wheel spins torque is sent to the other end. output speeds front and rear are the same though IIRC a while since i read about it
Soupie69uk
Post by Soupie69uk » Wed Apr 02, 2008 9:18 pm
It will be still 50/50 most of the time, but just can transfer more if needed. The current setup will allow up to 66/33.
kies4
Post by kies4 » Thu Apr 03, 2008 10:12 am
http://www.midlandbearings.com/INA2007JAN.htm can offer the LS3047 washers for around £8 I'm trying to read through and get my head round exactly whats needed.
Soupie as looking at the diagram is it only the outside washers, ie a washer 2 on top in the diagram and washer 3 on the bottom?
Washer Number 2: Purchase either INA or FAG thrust washer part number LS3047 (4 required).
Nominal Inside Diameter 30 mm
Nominal Outside Diameter 47 mm
Nominal Thickness 3 mm (as purchased)
Rework Outside Diameter 43 mm
Rework Thickness 1.94 mm
Washer Number 3: FNC washer not commercially available. Make from either INA or FAG thrust washer part number LS3047 (1 required).
Thickness 3 mm
Rework Outside Diameter 42.1 mm
Rework Thickness 1.98 mm
I'm going to try a bit more reading about
cheers
Users browsing this forum: No registered users and 108 guests
