40:60 front/rear split
I was absolutely sure the RS4 box/diff could split 25/75 eitherway vs 66:33 on the S4. Strange, oh well.
You just need to replace 2 washers in the front torsen that is in the gearbox.
The early cars its easy to take the torsen to bits as its 2 piece and is held together with screws. The later cars have a 1 pc torsen and pins hold it together.
Both types use different size washers.
There is some info.
http://torsen.com/fsae/012000_washer.htm
There is some info.
- tdiquattro
http://www.midlandbearings.com/INA2007JAN.htm can offer the LS3047 washers for around £8 I'm trying to read through and get my head round exactly whats needed.
Soupie as looking at the diagram is it only the outside washers, ie a washer 2 on top in the diagram and washer 3 on the bottom?
Washer Number 2: Purchase either INA or FAG thrust washer part number LS3047 (4 required).
Nominal Inside Diameter 30 mm
Nominal Outside Diameter 47 mm
Nominal Thickness 3 mm (as purchased)
Rework Outside Diameter 43 mm
Rework Thickness 1.94 mm
Washer Number 3: FNC washer not commercially available. Make from either INA or FAG thrust washer part number LS3047 (1 required).
Thickness 3 mm
Rework Outside Diameter 42.1 mm
Rework Thickness 1.98 mm
I'm going to try a bit more reading about
cheers
Thickness 3 mm
cheers
S4 Crazy Horse. Ringsticker & MRC black magic.
Users browsing this forum: No registered users and 108 guests
