I would not think that both sides would be gone... usally just 1 side will brake down before the other.BRETTCOLLINS wrote:Yes am thinking Rear hubs or bearings...
Darren
Only vibrates when braking, there is no vibration under hard acceleration, cruising speed or turning.boxerdogted wrote:Possible prop shaft. Center bearing worn or missaligned shaft.
Does it vibrate without braking ?.
do the pads sit in the carriers too deeply and extend pass the inner edge of the braking area ...?rolskii wrote: do the pads pass the inner edge of the disc ...?
do the pads overhang the centre of the floating disc ..? ..... enabling the pad to grab the underside edge of the disc ...?
