Suspension Top Mounts...advice...?????
Lig
Post by Lig » Tue Mar 04, 2008 7:11 pm
Hi Chaps,
I have been reading various threads about replacing DRC with KW etc... and members also mention replacing top mounts??
My car is currently waiting to have the DRC (shocks and valves) replaced under warranty, would it be worth me shelling out to replace the top mounts at the same time?? How much would this cost and does anyone have part codes for the said items???
Car has done 70K miles BTW.
Cheers in advance,
Lig.
shunt1tech
Re: Suspension Top Mounts...advice...?????
Post by shunt1tech » Tue Mar 04, 2008 8:43 pm
Lig wrote:Hi Chaps,
Cheers in advance,
Lig.
:? Hi Lig , unless the cars had impact damage or excessive corrosion there is no need to replace. Upper links arms yes if splitting bushes, play in ball joints or corrsion to ball joint where top pinch bolt is fixed . this top must be replaced if removed when front strut being taken out for damper change.
Stu.
Lig
Post by Lig » Wed Mar 05, 2008 9:46 am
Stu.
Hi Stu,
Thanks for your response, Just to clarify your comment above, all the shocks are being replaced so what should be replaced 'the top pinch bolts'?? and can I assume these will be changed as standard, I did notice on the quote there was about £20 or so for bolts etc??
Cheers,
Lig.
SimonY
Post by SimonY » Wed Mar 05, 2008 11:09 am
Lig,
Just to say that I had my DRC replaced back in November when the car had only covered 20K miles. As per the Bilstein upgrade sticky, asked Fontain to replace the top mounts and they did say that there was "some" wear and agreed it made sense to change them out at the same time. Cost for the 2 mounts was £56.80 plus the VAT.
Regards
Simon
Current
1985 Ur quattro in Alpine White
Previous
2004 RS6 Mugello Blue Avant | Milltek Non-Res | Bilstein PSS9 Coilovers | Hotchkis ARB | Black Optics Kit | RS6+ Coloured Alloys (Sold but never forgotten)
2015 RS4 in Riviera Blue
2016 RS6 in Utopia Blue
2002 S3 in Imola Yellow
Lig
RE: Suspension Top Mounts...advice...?????
Post by Lig » Wed Mar 05, 2008 2:11 pm
Cheers Simon,
I will ask the Audi Tech to have a look and advise....hmmmmm...I wonder what he will say....:lol:
grizz
Post by grizz » Wed Mar 05, 2008 8:10 pm
Lig , get all 4 top rubber mounts replaced as all the cars i've done have needed them . You don't need to undo the top pinch bolt . :?
Unit 20
0151 3366888
Lig
Post by Lig » Thu Mar 06, 2008 9:55 am
Thanks Grizz,
Are these the top mounts that SimonY mentioned above? Dont suppose you know part numbers or prices???
Cheers,
Lig.
SimonY
Post by SimonY » Thu Mar 06, 2008 10:50 am
Lig,
The part numbers and pictures of, are all in the Bilstein upgrade sticky but they're quoted as
*** Other Suspension Bits***
Qty Item Part Number
1-pair Front suspension top mounts 4D0 412 377 F
1-pair Rear suspension top mounts 8E0 512 121 D
Regards
Simon
Current
Previous
marmite
Post by marmite » Tue Mar 11, 2008 12:22 am
I agree replace them
I had my DRC replaced and I just ordered 4 top mounts nuts and bolts from DSwagen
03 RS6 Saloon Daytona Grey | Milltek | RS6+ Wheels | RS6 Mats | Tesco Club Card Points
Lig
Post by Lig » Tue Mar 11, 2008 2:41 pm
Interesting.....
The car is going in next week for valves and shocks replacing, and the service manager doesn't think the top mounts will need replacing, which is really honest as it would be easy for him to say get them done. He did say if the car was used for serious track work then maybe, but if its been used for general driving they would be fine??!!
He is going to check them when the car is in and I will report back what the outcome is??!!
Lig.
grizz
Post by grizz » Wed Mar 12, 2008 12:59 pm
There seems to be some confusion about top mounts , The fronts are a small rubber bush that sits under the top of the bearing bracket .
These fail all the time , i think they we mean the top bearing plate that is alloy .
Unit 20
0151 3366888
Rupert
Post by Rupert » Wed Mar 12, 2008 1:55 pm
Grizz, what are the symptoms of failing rubber bushes?
grizz
Post by grizz » Wed Mar 12, 2008 3:42 pm
It makes a light "knock" or rattle . Even when they are split they can still be quiet .
Unit 20
0151 3366888
SteveCuz
Post by SteveCuz » Wed Mar 12, 2008 5:55 pm
I wonder is that my problem. Since joining this forum I was sure my DRC was gone as I hear a rattle from time to time but my car was serviced last week and the mechanic said there was no sign of leaking and that if the system was drained I would really know about it when I was driving.
Also my car passed it's MOT today (was sweating all the way) and this included a test on the suspension.
Steve
2011 Audi RS3 Daytona Grey | 2003 Audi RS6 Avant Ebony Black
Lig
Post by Lig » Wed Mar 12, 2008 6:26 pm
I am sure they are referring to the alloy piece (as pictured at the beginning of the bilstein sticky).
So these small rubber bushes, would they be replaced by default when changing the shocks? Would you be able to see if they are shot when the shocks are removed?
Any idea of part number / price??
Cheers,
Lig.
Users browsing this forum: Google [Bot] and 56 guests
