Quick Question About Disconnecting Exhaust Valves
Terzo333
Post by Terzo333 » Fri Feb 15, 2008 11:40 am
Just double making sure I get it right, basically all I do is remove the black pipes and plug them ? Nothing more ?
Dom81
RE: Quick Question About Disconnecting Exhaust Valves
Post by Dom81 » Fri Feb 15, 2008 12:04 pm
Basically, yes
You should also close the open metal tube that's left when you pull the pipes off - either with a substitute closed bit of hose (if you're feeling hi-tec) or a foot of insulating tape (if you're like me) - doesn't need to be air-tight or anything, just a bit of weather proofing...
Couple of cable ties are also handy to keep the pipes from flapping about
2007 Daytona RS4 Avant
pippyrips
Post by pippyrips » Fri Feb 15, 2008 1:08 pm
use the search function - there is a very good post that includes pics etc within the forum which helped me to sort mine out :)
hairyaardvark
Post by hairyaardvark » Fri Feb 15, 2008 1:27 pm
Yup me too - found a great thread on here. In the end I did a fairly neat job, blocking the black tubes with a screw and a crimped mini-clamp in each case, that I got from Halfords for about 1.99 .
P_G
Post by P_G » Fri Feb 15, 2008 6:00 pm
If you use a mini clamp on the hoses anyway, would you really need to disconnect them from the open metal tube section? Just clamp the hoses until airtight?
pippyrips
Post by pippyrips » Fri Feb 15, 2008 10:06 pm
The better way is to disconnect the pipe from the green connector at the opposite end to the actuator, this leaves absolutly no signs of tampering once put back on.
I found this little gem out the day after i did mine :roll:
Ozrs4
Post by Ozrs4 » Fri Feb 15, 2008 11:24 pm
pippyrips wrote:The better way is to disconnect the pipe from the green connector at the opposite end to the actuator, this leaves absolutly no signs of tampering once put back on.
Absolutely and it's much easier to pull the pipes apart at this junction than pulling the black pipe off the valve part! :thumbs:
