INTERCOOLER
- 5th Gear
jeff.the sportec grilles are the same mesh pattern as stock but without the fog light holes , ps catching you up
665 bhp + 586 lbft...
- 5th Gear
the duh intercooler is a bit thinner than this one and with the pipework being a bit smaller diameter doesnt stick out as far at the sides. my iat,s are a constant 15 degrees above ambient temp without the number plate which sheilds the top half of the cooler!
That sounds like a wicked idea. Don't suppose anybody has a pic?jimbo1234567 wrote:everything is going to be for sale shortly ie, rs4 intercoolers ,pipes ,shrouds ,fogs ,grilles,mtm chip,oil cooler with pipes, pas cooler,air con fan and maybe the down pipes depending weather i can live with the noise. as for the plate i saw another car at mrc that had the numbers and letters removed by laser just leaving a white backing.
Rs4 b5 06/2001
custom remap - KW V3 - Hotchkis Sways - ASP DTS with poly mount - 034 Street Mounts + Snub with bracket - Apikol rear diff mount and bushes - Gutted precats - DUH Fmic kit - 360x32 floating discs+brembo 6-pot at the front - 710Ns - OEM 18 Hard wheels - JHM shifter/linkage/spring etc - Podi.ca Boost Gauge - Powerflex Bushes - Afterrun mod -
So what about the Duh FMIC???
Thank you
Thank you
Rs4 b5 06/2001
Me too.
2 months ago and 3 days ago. Still no reply
bye
bye
Rs4 b5 06/2001
Sorry for the late response, Yea.. It's a DUH, it took a while to fit it right.. The only problem is the Intercooler blocks the the radiator quite a bit. the water temp never below 90 degrees, After some WOT it can go as high a bit over 90. By the way, what kind of water temp are you guys running?neily wrote:hey that is looking VERY nice indeed. What FMIC kit was used ?
Users browsing this forum: Majestic-12 [Bot] and 37 guests
