APS Remap Review
audijohn
Post by audijohn » Thu Feb 07, 2008 6:54 am
nick555 wrote:
When a remap is done via the OBD port a "Signature" is left behind, resetting the counter does not take this out from talking to tuners.
All the Cars I have had done, used the Imbedded method and never been seen.
Flashing is both cheap and skilless, anyone can do it with limited knowledge.
That's why all these companies have "Sprung up" from no where.
It is common knowledge that the "Flash" method is "Less Safe".
If you are concerned ask another big tuning house what they think.
which uk tuners us the imbedded method?
thanks
This guy is level headed and gives no BULL
http://www.p-torque.co.uk/
His name is Will, he will tell you the safest way to go.
t_urbo
Post by t_urbo » Thu Feb 07, 2008 5:21 pm
R33V-Spec wrote:Another thing I got told by a reputable tuner is that with "flashing", you cannot determine the exact version of the ECU, for example the ECU may have been uploaded with the latest software, i.e B7 RS4 from Audi.
All they analyse is the ECU type, and then upload a suitable map via the OBD. Whereas custom maping can be suited to the exact version.
That is NOT true.
When i had mine done JD Engineering knew it had the old software and uploaded the newest version before he carried out the remap.
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Thu Feb 07, 2008 10:28 pm
Yep but JD's map might be based/suited to the latest B7 software thus why he uploaded the latest software before proceeding with the mapping...
Virdee Autos ~ 07950-526592
t_urbo
Post by t_urbo » Thu Feb 07, 2008 11:16 pm
R33V-Spec wrote:Yep but JD's map might be based/suited to the latest B7 software thus why he uploaded the latest software before proceeding with the mapping...
Indeed it is, but he knew i had the old version when he hooked the ecu's up to his laptop.
Also anyone can read what version they have just from Vag-Com, its not rocket science.
MikeD
Post by MikeD » Fri Feb 08, 2008 6:08 pm
Any chance of a before and after dyno run/plot, that would show all?
S4(b5)Avant ,K04's+Milltek pipes+ECU+full QST
RS4(b7)Avant ,ss+, standard "for now" ,
Ariel Atom 3, 300 with extras!
Adam
Post by Adam » Fri Feb 08, 2008 11:03 pm
SR71 wrote:Questions....
1) Did you APS-mapped guys get your top speed limiter removed?
2) Will they increase the rpm red line limit if you so wished?
3) I understand that in 1st, 2nd and 3rd, prior to ~5500rpm, putting your foot flat down on the throttle does still not demand 100% throttle (hence the additional rush in the stock car that seems to happen at that point). Does the map remove this restriction?
Thanks.
1 yes
2 don't know did not ask
3 not sure but think so as it smoothes out that step at 5k and revs more willingly
Users browsing this forum: Google Adsense [Bot] and 120 guests
