Heater/air-con has packed up.
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Ads4
Post by Ads4 » Mon Nov 26, 2007 10:10 pm
Zilch. Nada. Nothing. Kaput. I think it's broken. :(
The vents no longer emit an air flow. :shock: This has been an intermittent problem for the last week but is now permanent and i now need to drive with a window open to keep the interior from misting up. Has the fan broken or could it be a fuse? Or a whole new heater unit needed? I know nothing (nada. zilch.) about the heating system so would welcome some advice please! :D
Adam.
MRC B5 S4 Avant.
Peakz
RE: Heater/air-con has packed up.
Post by Peakz » Mon Nov 26, 2007 10:26 pm
Check the fuse first, at the very end of the dash (nearside), the panel has diagram if I remember correctly.
Could also be the brushes on the heater motor but that would get gradually worse over a longer pweriod, new brushes are only around £50 fitted from your local washing machine repairer.
I can't remember if the resistor pack on these is susceptible to failure but that's another cause I guess.
Peakz
Post by Peakz » Mon Nov 26, 2007 10:27 pm
Hmmm, my first double-post!
CliveH
Post by CliveH » Mon Nov 26, 2007 10:28 pm
Adam - do you have access to VAG-COM?
Any fault codes should give you a clue to where the problem lies.
Clive
CliveH
Re: RE: Heater/air-con has packed up.
Post by CliveH » Mon Nov 26, 2007 10:30 pm
Peakz wrote:Hmmm, my first double-post!
It's not too late to remove it...or are you just trying to get into 4th gear...? (as usual :roll: )
Clive
Harper--D
RE: Re: RE: Heater/air-con has packed up.
Post by Harper--D » Mon Nov 26, 2007 10:34 pm
If i rember rightly, there was a HVAC fault code on the rr day!
Dave.
White MK2 Golf.. Slightly modified :D
MarkB
Post by MarkB » Mon Nov 26, 2007 10:36 pm
What double post? :sekret:
Mark
MarkB
Post by MarkB » Mon Nov 26, 2007 10:37 pm
Adam, if you're local to me any time soon I'd happily scan the car for you...
Mark
Ads4
Post by Ads4 » Mon Nov 26, 2007 10:38 pm
Address 08: Auto HVAC Labels: None
Part No: 8D0 820 043 N
Component: A4 KLIMAAUTOMAT D56
Coding: 00061
Shop #: WSC 06325
1 Fault Found:
01273 - Fresh Air Blower (V2)
17-00 - Control Difference
Means nothing to me :biggrin2:
Adam.
MRC B5 S4 Avant.
Peakz
Post by Peakz » Mon Nov 26, 2007 10:48 pm
Fault Code 01273 - http://wiki.ross-tech.com/index.php/01273
MarkB - Thanks for sorting out my double-post.
Ads4
Post by Ads4 » Mon Nov 26, 2007 11:08 pm
Looks like my 'Fresh Air Blower (V2)' is defective then?! New unit required? Trip to the stealers then...
Adam.
MRC B5 S4 Avant.
Peakz
Post by Peakz » Mon Nov 26, 2007 11:22 pm
Take the blower motor out from behind the glovebox first, a slightly fiddly job. Once it's out check the motor brushes for excessive wear, if they're worn it's a cheap fix. Shouldn't take you longer than forty minutes to take it out, even less to put it back once you've remembered where all the screws go.
s4woody
Post by s4woody » Mon Nov 26, 2007 11:37 pm
that part number is for the control unit that sits in the centre console..about £570 inc vat..well thats stealer price anyways...
or to put it into ringlish..its your climate control panel..
the control panel without the heated seat unit is a mere £501.00 inc vat..
GARTH ROAD MOT CENTRE LTD
020 83353032
tartan_rob
Post by tartan_rob » Tue Nov 27, 2007 10:06 am
Or get one on ebay for peanuts.
2017 Kawasaki Z1000
2014 RS6
2014 S1
Peakz
Post by Peakz » Tue Nov 27, 2007 1:18 pm
Sheesh kebab £570!!
Users browsing this forum: No registered users and 72 guests
