Really bad engine noise that comes and goes
2.7 V6 30v biturbo - 380 bhp
lagermonkey
Post by lagermonkey » Sat Oct 27, 2007 6:42 pm
My RS4 (B5) has started to sound very rough on two occasasions now. After the first time, I garaged the car immediately, and got it AA'd to the dealer's garage. When it was started up again, the noise was completely gone. The dealer had the car for a week but found nothing wrong.
The car has been fine for a few weeks now, but it started making the noise again today and I've video'd it (though I cannot attach it to the post for some reason). The engine management system light flashed a couple of times when the engine was idling, but has gone of again.
Has anyone experienced this type of intermittent noise before?
Does anyone know what the noise is? It is a loud "rattle" coming from the middle of the engine compartment. It's frequency increases with the engine revs. The engine basically sounds like a badly worn diesel engine (imagine you are standing next to a taxi and that is pretty much spot on)
Would anoyone recommend sending the car straight to an Audi dealer or are there specialists who are better skilled to diagnose and fix these beasts?
Any help would be greatly appreciated!!
lagermonkey
Post by lagermonkey » Sat Oct 27, 2007 7:18 pm
zipped mp3 of noise attached...
DSCF1456.rar
Not a lawn mower - honestly...
(134.23 KiB) Downloaded 113 times
dssean
Post by dssean » Sat Oct 27, 2007 7:47 pm
start by getting it scanned or vagcommed. if the mil flashed on its stored a code. i'm guessing its the secondary air system that blows air in to warm the cats up. ( but i can't download your noise).
but the scan will point you in the right direction.
p.s where abouts do you live so any member with vagcom might be near by.
lagermonkey
Post by lagermonkey » Sun Oct 28, 2007 1:14 am
Thanks for responding.
am in Berkshire.
Know anyone nearby?
jeffw
Post by jeffw » Sun Oct 28, 2007 7:49 am
Sounds like the valves are out....maybe a hydraulic tappet ? Best thing to do is get the car over to MRC in Banbury (www.mrctuning.com) and let them have a look/listen to it.
lagermonkey
Post by lagermonkey » Sun Oct 28, 2007 12:14 pm
Sounds like a plan.
Will limp it over to MRC as soon as they can fit me in.
Many thanks!
Jim
SJS
Post by SJS » Wed Oct 31, 2007 5:05 pm
Ignition amplifier maybe? I had a 1.8T that had a faulty amplifier ( 2x sit on top of the airbox on the S4) and when it went faulty it sounded like it was running on three cylinders. It came and went once or twice then was permanent. There is a test you can do somewhere to verify they are fully working.
Nogaro S4 Yr2000. MRC remap, K04s, Milltek
CVB
Post by CVB » Fri Nov 02, 2007 12:04 am
Hi,
I cant open your sound file, but i had a what could be a similar problem.
The RS4 engine has a cam chain that is tensioned by a hydraulic piston and chain guide. If the piston becomes worn it will allow the cam chain to get loose and rattle like hell. By the time i had got the car in to be fixed it had worn a hole in the rocker cover!!
Defo' worth checking this.
Hope you get it resolved soon.
TopBear
Post by TopBear » Fri Nov 02, 2007 12:20 am
I'd try and get someone local to you to run a VAG-COM scan, and see what error codes are being thrown up. Suspect it will be lots of random misfire codes by the sound of it.
Hopefully its not serious mate.
:blackrs4: B5 RS4, MRC Remap, Milltek, RS6\B7 Brakes, Black\Carbon
Contigo
Post by Contigo » Fri Nov 02, 2007 4:33 pm
I'm in Newbury Berks and have VAG COM if you want to pop it round
2001 Avus Silver RS4 B5 60k on clock, MRC Custom Remap, Sunroof, Bluetooth prep
2006 Daytona Grey RS4 B7, RNS-E - SOLD
2006 BMW M6 - GONE
NigelS4
Post by NigelS4 » Fri Nov 02, 2007 5:10 pm
If it sounds like marbles in the engine bay, it's most likely the water pump failing
Users browsing this forum: No registered users and 23 guests
