SAT NAV TV PLUS
2.7 V6 30v biturbo - 380 bhp
FUZZY
SAT NAV TV PLUS
Post by FUZZY » Fri Oct 05, 2007 1:03 pm
Does anybody know anything about retro fitting a SatNav tv plus system, I have RS4 B5 and want to replace head unit, there are several available on EBAY but does it work ? is it easy to do or is it not worth bothering with ??
saf
RE: SAT NAV TV PLUS
Post by saf » Fri Oct 05, 2007 1:32 pm
Install the RNS-E. Its a much better unit.
Apparantly theres a guy here that does specialised installs. I think he may be a member of the forum.
Hopefully someone will be along to give you his contact detials.
FUZZY
Re: RE: SAT NAV TV PLUS
Post by FUZZY » Fri Oct 05, 2007 4:18 pm
Many thanks, it seems a mine field with lots of different ideas
Blue_Thunder
RE: Re: RE: SAT NAV TV PLUS
Post by Blue_Thunder » Fri Oct 05, 2007 6:51 pm
I think saf's thinking of CraigyB, but he had a disagreement with the mods so you won't find him on here anymore.
saf
Post by saf » Fri Oct 05, 2007 8:07 pm
That was the dude.
Fair enough. I didnt know about the disagreements.
shineydave
Post by shineydave » Sat Oct 06, 2007 8:17 am
depends which existing head unit you have as to how easy the conversion is. if you have the Symphony it's a doddle, anything else is a PITA. there's loads of info on this in the forums, try a search
