@S2 Tuner - Rev Limiter
2.7 V6 30v biturbo - 380 bhp
Norrs2
Post by Norrs2 » Tue Oct 02, 2007 12:06 pm
Does my MRC Custom re-map still have a rev limiter? When giving it a "run out" I noticed a couple of times the rev counter go up to over 7500 rpm (by accident) when not clocking the rev counter quick enough.
Obviously, I don't want to damage the Engine by not paying attention. I know, I know, I should be able to tell by ear now but it's only in the lower gears when it just goes up so quickly :)
Anyone else's do this?
B5 RS4 - Santorin Blue Pearl
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
Miltek Cat Back SS Exhaust
1988 Pearl White MB Ur quattro (Genesis)
DavidT
RE: @S2 Tuner - Rev Limiter
Post by DavidT » Tue Oct 02, 2007 12:16 pm
Yep, fear not. I think all the B5 cars do it, mine goes to 7800 on the rev counter but its not accurate as VAG-COM says it only every get 7220. My limiter is 7200.
I'm sure an MRC person will verify this for you :)
RSpimp
Post by RSpimp » Tue Oct 02, 2007 3:07 pm
i have mrc custom map and hit limiter last night ! so am sure it still has one ..couldnt tell you what rpm it is though
Ads4
Post by Ads4 » Tue Oct 02, 2007 6:49 pm
Had the same fear when I had the MRC400...couldn't find the limiter where I thought it should be and worried I'd blow the thing up!! Needless to say once I got used to the upgrade and stopped worrying I soon found that it had one, higher than I thought it'd be :D
Adam.
MRC B5 S4 Avant.
S2tuner
Trader (Expired)
Post by S2tuner » Tue Oct 02, 2007 11:46 pm
Norman, your rev limiter is set at 7200, pretty much a default for my RS4 maps... so no worries, it is still there ;)
And rev counters aren't accurate at all past 7k, my own S4 revs up to 7800 according to the dials, but it is at 7400 and no higher, plus it's a hard cut so it rarely goes above 7400, maybe 7420 but that's it. Stage 3 S4s are also pretty much default at 7200. ;)
HTH,
Mihnea
Norrs2
Post by Norrs2 » Wed Oct 03, 2007 7:47 am
Thanks for the reassurance folks!
:thumb:
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
