vagcom
vagcom
hi lads,thinking of getting a vagcom from rosstech ,which software would you recommend for maf readings and fault codes as this is what i'll be using it for , and how easy are they to use ,because i'm a bit of a dinasaur on a computer .ta belly
RE: vagcom
You want this.... http://www.ross-tech.com/Merchant2/merc ... ode=VAGCOM
Use the VagCom software that you can download from Ross Tech
- Top Gear
VAG-COM comes with (real) USB drivers for the genuine Ross-Tech interfaces, but if you are using a 3rd party interface your have to (as Blue Thunder already described) find the appropriate drivers yourself. Usually they come with your 3rd party hardware or the seller gives you a download location, if in doubt just contact the seller - he should know.
Sebastian @ Ross-Tech.com
Users browsing this forum: No registered users and 11 guests
