Much better
Ozrs4
Post by Ozrs4 » Sat Sep 15, 2007 2:33 pm
hugy wrote:After doing this mod,what happens when the S button is pressed?Does the sport mode still work?
I believe it still work for the throttle mapping and sport (bucket) seat activation. So you still wanna press the S button for spirited driving.
I-want-an-RS
Post by I-want-an-RS » Sat Sep 15, 2007 3:20 pm
I can't belive that the RS has been out for 2 years almost and people are only starting to do this now, I told my mate to do this before he got his car last year.
DoctorD
Post by DoctorD » Sat Sep 15, 2007 6:10 pm
Nothing, in terms of the sound, although the S button still activates the Sport engine map.
t_urbo
Post by t_urbo » Sat Sep 15, 2007 6:22 pm
There is no sport engine map.
Two maps, one for the first 3 gears and one for gears 4-6.
If you disconnect the flaps then pushing the sport button will just adjust your seat.
Attranac
Post by Attranac » Sat Sep 15, 2007 8:22 pm
t_urbo wrote:There is no sport engine map.
What about the throttle response?
audijohn
Post by audijohn » Sat Sep 15, 2007 8:33 pm
S4INT wrote:I did this to mine a couple of days ago, and have to agree with everything written before. Car now feels more torquey and responsive at low revs, mpg marginally better, and no issues with extra noise, except on cold start where it now makes the house vibrate.... :D
Love it. :D
audijohn
Post by audijohn » Sat Sep 15, 2007 8:37 pm
Sport button still give the throttle responce, I tried it and confirmed it with Will at p torque. So "s" button still works. :wink:
alex_123_fra
Post by alex_123_fra » Sat Sep 15, 2007 8:52 pm
I just finished disconnecting my exhaust flaps so they remain open all the time. Quite easy...my main difficulty was disconnecting the 2 black pipes without damaging the micro-fastening clips. Still...managed to do it in the end.
Car sounds much better at lower revs than previously. Haven't driven much post the mod but it certainly feels a bit meatier. Thank you to all for the helpful instructions.
Re: Sport mode...I thought it had already been proven by Jeroen that the sport map gives slightly more torque (but ultimately same power) in lower revs compared to non-sport mode. Is this increase in torque dependent on the flap opening rather than a map change?
Current: C7 RS6 - Black, VW Passat CC R36 - Black, Freelander 2 - Black
Sold: 911 C4S (991) - Black, Panamera Turbo ('11) - Carrera White, Nissan GT-R - DMG, B8 S4 - Phantom Black, B7 RS4 - Daytona grey saloon, Noble M400, Golf R32, Evo VIII MR, M3, Cooper S, Civic Type-R, BMW 120D (black), Mazda 6 MPS
pippyrips
Post by pippyrips » Sat Sep 15, 2007 10:30 pm
alex_123_fra wrote: Is this increase in torque dependent on the flap opening rather than a map change?
More than likely
t_urbo
Post by t_urbo » Sat Sep 15, 2007 10:36 pm
More than likely
Thats right the 10Nm torque increase is due to the flaps opening,
there is no map change
t_urbo
Post by t_urbo » Sat Sep 15, 2007 10:44 pm
yeah it shortens the throttle throw but it doesn't make any difference to the max throttle angle which remains the same under 5500rpm ( 50-60% throttle) regardless of what mode you are in.
Its explained better here by Jeroen of JD Engineering where i got my remap from.http://www.rs246.com/index.php?name=PNp ... c&start=45
Mori
Post by Mori » Sat Sep 15, 2007 11:17 pm
I assume Sport mode will work (change the throttle map, seat bolsters will tighten etc.) but the exhaust will not open, since it already is.
Ozrs4
Post by Ozrs4 » Sun Sep 16, 2007 1:19 am
Well, Gents. I'm now also a member of the Permanent Open Exhaust Flaps (POEF) club. Hehee. I reckon I gotta be the first one in Sydney to do this. :bigblink:
Thanks for all the info. The drivability does seem better at low revs. I must say though pulling the black pipe off the 90 degree connector (which attach to the smaller green pipe) is much easier to do by hands, no need for flat nose pliers and no chance of damaging the factory clips. Then as you all did, simply plug the open ends with some screws. All done in 3 mins.
2007 RS4 B7 - Phantom black saloon
nidfix
Post by nidfix » Mon Sep 17, 2007 2:02 am
That post was very interesting.
So it looks like Audi did for the RS4 the same thing that they did with the S4v8. Form what I remember, they did to respect some emission regulations.
The funny thing is that now for more than a year, the map defined for the S4 does not close the flaps anymore...
I am a bit surprised they did not apply yet the trick on the RS4 :roll:
kaisersolsay
Post by kaisersolsay » Tue Sep 18, 2007 10:01 pm
Hi guys,
Will this work on my B6 S4 or is this mod only for the RS4?
Users browsing this forum: Google [Bot] and 91 guests
