Hi all
What sort of codes would a knackered / failing / noisey turbo produce? In other words what should I see from vag-com if there is a problem? Or can they go without throwing any codes??
Ta
Chris
Turbo related codes
Turbo related codes
Goodwood RS4 (B5) Stage 1 MRC
RE: Turbo related codes
You could try doing some runs and checking your boost/maf readings as a starting point.
- Top Gear
Requested and Actual boost would let you know if there was a boost leak - Think it's block 115
Doubt you would get any error codes for a dying turbo though. As far as I know, there aren't any sensors in a turbo, it's a purely mechanical beast.
If the boost is down badly you will get "Charge pressure lower limit not reached"
Users browsing this forum: No registered users and 9 guests
