Possibly, but thats not gonna be cheap if the gear is 200 quid!!!dummi wrote:they'd be more likely to sell you the whole box, but maybe that is the quickest way
Longer 6th gear ?
Re: RE: Re: RE: Re: RE: Re: RE: Longer 6th gear ?
RE: Re: RE: Re: RE: Re: RE: Re: RE: Longer 6th gear ?
Does anyone have the program to check what box it actually came out of? ie year/model etc? I was thinking that a second hand box out a diesel might not be too expensive ..?
I have also found Part no 01E 311 362 D which seems to have a ratio of 0.6 ... so, would this work as well!!?
God I am getting confused! http://www.vagcat.com/epc/search/?pn=01E311362D
here are some tightening torques for you for oiled bolts
Threaded assemblies
Tightening torque
Nuts and bolts
M6
10 Nm
M8
20 Nm
M10
45 Nm
M12
60 Nm
Except for the following:
Head line to turbocharger
25 Nm
Heat shield to turbocharger
10 Nm
Clamp for exhaust pipe
40 Nm
Engine support to engine mount
M10
45 Nm
A/C Compressor to bracket
25 Nm
Torque support
45 Nm
Heat shields above drive axles to transmission
25 Nm
the gearbox to engine are all 65nm including those next to the starter. except for the bottom that are 45nm
to install the gearbox
Clutch slave cylinder to transmission 1)
20
Transmission support to transmission
40
Engine speed sender -G28-
10
Drive axle to drive flange
M8
M10
40
70
25
Push rod to transmission
40
Selector rod to transmission
23
Connecting rod for selector rod to transmission
23
Catalytic converter to mounting lugs
25
Front exhaust pipe to turbocharger
30
Heat shield to turbocharger/exhaust pipe
10
40
Bracket for noise insulation to subframe
10
Propshaft to transmission 1)
55
Heat shield for driveshaft to Torsen differential cover
25
cheers
Rez
Threaded assemblies
Tightening torque
Nuts and bolts
M6
10 Nm
M8
20 Nm
M10
45 Nm
M12
60 Nm
25 Nm
10 Nm
40 Nm
M10
45 Nm
25 Nm
Torque support
45 Nm
25 Nm
20
40
10
M8
M10
40
70
25
40
23
23
25
30
10
40
10
55
25
cheers
Rez
Users browsing this forum: No registered users and 100 guests
