Longer 6th gear ?
2.7 V6 30v biturbo - 380 bhp
viperbl
Re: RE: Re: RE: Re: RE: Re: RE: Longer 6th gear ?
Post by viperbl » Mon Aug 06, 2007 1:28 pm
dummi wrote:they'd be more likely to sell you the whole box, but maybe that is the quickest way
Possibly, but thats not gonna be cheap if the gear is 200 quid!!!
RS4 B5 Saloon8) with 750+ bhp :D
viperbl
RE: Re: RE: Re: RE: Re: RE: Re: RE: Longer 6th gear ?
Post by viperbl » Mon Aug 06, 2007 2:22 pm
Does anyone have the program to check what box it actually came out of? ie year/model etc? I was thinking that a second hand box out a diesel might not be too expensive ..?
MarkB
Post by MarkB » Mon Aug 06, 2007 3:05 pm
This info...
gearbox part.JPG (25.88 KiB) Viewed 894 times
Mark
MarkB
Post by MarkB » Mon Aug 06, 2007 3:09 pm
and this?
gearbox gears.JPG (203.02 KiB) Viewed 892 times
Mark
viperbl
Post by viperbl » Mon Aug 06, 2007 3:09 pm
Thanks Mark ... So wait a min, does that mean that the S4 box has the longer 6th gear??!?
MarkB
Post by MarkB » Mon Aug 06, 2007 3:11 pm
I think it's refering to Diesel Quattros I would hope. Rob should be able to confirm against model of car
Mark
viperbl
Post by viperbl » Mon Aug 06, 2007 3:29 pm
I have also found Part no 01E 311 362 D which seems to have a ratio of 0.6 ... so, would this work as well!!?
God I am getting confused! http://www.vagcat.com/epc/search/?pn=01E311362D
dummi
Post by dummi » Mon Aug 06, 2007 4:14 pm
you might be able to get a box for 200 or less
well the part number beginning '01E' is encouraging on your alternative
viperbl
Post by viperbl » Fri Aug 17, 2007 11:30 am
Here's a good one!!!
I got the 6th Gear, - 01E 311 362 L (0.6 Ratio), right, my gearbox man has now informed me this only half of it, I need the other gear that it will mate to on the other shaft!
Can anyone work out the part number for this other gear???!??!??!?
viperbl
Post by viperbl » Fri Aug 17, 2007 12:21 pm
Update, with the help of DSGWagon we found the output shaft 6th gear is 01E 311 165 J.
So, another week to wait now!!! will it be ready in time!
dummi
Post by dummi » Sat Aug 18, 2007 7:54 am
here are some tightening torques for you for oiled bolts
Threaded assemblies
Tightening torque
Nuts and bolts
M6
10 Nm
M8
20 Nm
M10
45 Nm
M12
60 Nm
Except for the following:
Head line to turbocharger
25 Nm
Heat shield to turbocharger
10 Nm
Clamp for exhaust pipe
40 Nm
Engine support to engine mount
M10
45 Nm
A/C Compressor to bracket
25 Nm
Torque support
45 Nm
Heat shields above drive axles to transmission
25 Nm
the gearbox to engine are all 65nm including those next to the starter. except for the bottom that are 45nm
to install the gearbox
Clutch slave cylinder to transmission 1)
20
Transmission support to transmission
40
Engine speed sender -G28-
10
Drive axle to drive flange
M8
M10
40
70
25
Push rod to transmission
40
Selector rod to transmission
23
Connecting rod for selector rod to transmission
23
Catalytic converter to mounting lugs
25
Front exhaust pipe to turbocharger
30
Heat shield to turbocharger/exhaust pipe
10
40
Bracket for noise insulation to subframe
10
Propshaft to transmission 1)
55
Heat shield for driveshaft to Torsen differential cover
25
cheers
Rez
s4woody
Post by s4woody » Sat Aug 18, 2007 10:44 am
KIS auto parts can supply the genuine Audi gear for £195 inc vat..
GARTH ROAD MOT CENTRE LTD
020 83353032
viperbl
Post by viperbl » Sun Aug 19, 2007 12:28 pm
Dummi, TOP MAN :D
I-want-an-RS
Post by I-want-an-RS » Sun Aug 19, 2007 7:00 pm
Right, please tell me that the gearbox from a 2.5TDi A4 quattro will have the bits I need
because I've just bought one from a 60k mile car for £50 and he's delivering it to my door
dummi
Post by dummi » Sun Aug 19, 2007 9:17 pm
sounds right you got a bargain whats the box code or pn
