LPG converted S4
LPG converted S4
http://www.pistonheads.com/sales/203890.htm
a mate is looking at buying this anyone had any issues with LPG ?
thanks all
thanks all
S4 Crazy Horse. Ringsticker & MRC black magic.
RE: LPG converted S4
That's the first one I've ever seen that's had it done!
Hi there that S4 was advertised about a month or so ago twice. at the time some members said that it looked like it was "sat strangely and that something else was dodgy about it just to let you know
Too many mods - Not enough overtime !
as for the lpg there should not be a problem with it, far as I know there is a lpg kit on a mitsubishi evo with 700bhp with no prob'e. My old man has ls400 4.0 v8 on lpg and still drives like a bueaty.
1.9TDI A6 are sh*t wrong forum
- ChipHazzard
that'll be this one that was discussed last time
http://www.rs246.com/index.php?name=PNp ... ic&t=61967
and here as well
http://www.rs246.com/index.php?name=PNp ... hlight=lpg
and here as well
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
I bought a boat from a guy a couple of years back who worked for a company that installed LPG kits (near Salisbury). He used to race a tuned S4 on LPG in some challenge cup.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
MRC have some experience with LPG and turbocharged Audi's
thanks all I'll read up about the motor and let my pal know
cheers
kie
cheers
kie
We took the car for a spin after I reset these engine codes on VAGCOM the following codes came back I reckon as a result of running on gas for the lean readings but are the Lambda sensors gone ?
if so any ideas on replacement cost ?
the car was clean as a whistle and has a full stealer service history, it has been LPG for 50k of its 100k just think maybe the lambdas may have had enough but done really know
5 Faults Found:
17538 - Fuel Trim; Bank 2 (Mult): System too Lean
P1130 - 35-10 - - - Intermittent
16534 - Oxygen (Lambda) Sensor B2 S1: Malfunction in Circuit
P0150 - 35-10 - - - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-10 - - - Intermittent
17546 - Fuel Trim: Bank 2 (Add): System too Lean
P1138 - 35-10 - - - Intermittent
Readiness: 0000 0000
5 Faults Found:
i know lpg has lower emissions that are not picked up by lambda's sometimes, did you get the problem on petrol? if not then its the lpg, for example my mate had a engine management light come on his impreza with lpg it was running so clean
Users browsing this forum: No registered users and 69 guests
