Heavy Clutch on quick change?
Saint
Post by Saint » Sun Jun 03, 2007 12:51 am
Hi Guys,
Been meaning to ask the dealer about this but just not had any time recently. My car went in for the TMC and at the same time, they upgraded my car software. I am not sure if this caused the problem or the problem was there before, but when I am in quick change mode and tramp down on the clutch, it gets extremely hard. This is quite disconcerting when you are trying to overtake and need to clear 2 gears only to have the clutch become extremely heavy.
Has anyone else experienced this? Any idea what could be causing it?
Thanks.
sykotoy
RE: Heavy Clutch on quick change?
Post by sykotoy » Sun Jun 03, 2007 8:38 am
you mean like 5th to third?
RS4 B7 Sedan 2006 Phantom Black
Solar Panel Sunroof / I pod
MODS- H+R Springs / H+R Front/Rear Sway Full Milltek This week
Current B7 RS4 1/4 mile record holder 12.883
E46 M3 SMG sold / But not forgotten
Chrysler Crossfire Roadster - sold
Saint
Post by Saint » Sun Jun 03, 2007 9:01 am
No, not necessarily ... it happens on any gear change. What seems to trigger it is how hard and how fast you depress the clutch. The faster and harder you do it, then harder it becomes ...
alex_123_fra
Re: RE: Heavy Clutch on quick change?
Post by alex_123_fra » Sun Jun 03, 2007 9:25 am
Saint wrote:No, not necessarily ... it happens on any gear change. What seems to trigger it is how hard and how fast you depress the clutch. The faster and harder you do it, then harder it becomes ...
Saint, sorry to hear about your clutch issue. I hope it is not this but on the earlier cars there is a known issue with the clutch vacuum assist line which controls clutch actuation. As the line collapses, it squeezes off the vacuum at the same time as you're depressing the pedal. This causes the pedal to go stiff.
You can test for the problem by letting the car sit at idle and then press the clutch repeatedly as fast as you can. If the pedal stiffens, you have the issue.
I would avoid driving too spiritedly unless you get audi to check it and ensure your car has the more updated vacuum line. If this isn't the problem, it would be interesting if you report back with details.
Best of luck.
Alex
Current: C7 RS6 - Black, VW Passat CC R36 - Black, Freelander 2 - Black
Sold: 911 C4S (991) - Black, Panamera Turbo ('11) - Carrera White, Nissan GT-R - DMG, B8 S4 - Phantom Black, B7 RS4 - Daytona grey saloon, Noble M400, Golf R32, Evo VIII MR, M3, Cooper S, Civic Type-R, BMW 120D (black), Mazda 6 MPS
RI_RS4
Clutch Vacuum Line
Post by RI_RS4 » Mon Jun 04, 2007 6:14 am
I'd second Alex. Sounds like the clutch vacuum line collapsing.
To test, put your car in neutral and depress your clutch multiple times as fast as you can. If it stiffens, you have the problem.
sykotoy
RE: Clutch Vacuum Line
Post by sykotoy » Mon Jun 04, 2007 9:52 am
can this problem be fixed under warrenty?
alex_123_fra
Re: RE: Clutch Vacuum Line
Post by alex_123_fra » Mon Jun 04, 2007 2:01 pm
sykotoy wrote:can this problem be fixed under warrenty?
Sykotoy, if the issue is with the vacuum line, the dealer has to fix it under warranty with the updated one. This isn't a "wear and tear" issue as audi already know.
Saint
RE: Re: RE: Clutch Vacuum Line
Post by Saint » Wed Jun 06, 2007 11:16 pm
Guys, thanks for the heads up. You've got me worried now. Must get on to the dealer asap. I have tried this test previously and it consistently happens.
Saint
Post by Saint » Fri Jun 22, 2007 9:20 pm
Guys, took it to the dealer and confirmed that this was the problem. They have sorted it out under warranty and it drives fantastic again. I printed out this thread and left it in the car just so that they were clear on what to do.
Thanks for your help!!!!
Much appreciated.
S.
audijohn
Re: RE: Re: RE: Clutch Vacuum Line
Post by audijohn » Sat Jun 23, 2007 7:14 am
Saint wrote:Guys, took it to the dealer and confirmed that this was the problem. They have sorted it out under warranty and it drives fantastic again. I printed out this thread and left it in the car just so that they were clear on what to do.
Much appreciated.
S.
Saint, the guys on here are SOOOO helpful, I have had ALL my questions answered and I now in tern help answer others questions, where would we be without these great forums. :D
alex_123_fra
Post by alex_123_fra » Sat Jun 23, 2007 9:02 am
Glad we could help Saint. Enjoy the car :D
I agree with John, this forum is great and everyone shares knowledge so readily. I really don't know what people did pre-internet era. The dealers must have been quite a lot busier!
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 161 guests
