hademade exhaust!
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
HobsonS4
hademade exhaust!
Post by HobsonS4 » Sat May 26, 2007 4:53 pm
i decided i was guna try and make my own exhaust system, well back box anyway. i removed the original backbox and i have replaced it with straight trough 2.5" stainless tube it was my 1st attempt so it took a bit of work but im chuffed to bits with the results, sounds awsome looks pretty standard from the outside too. i have a video ready to put on youtube so ill put a link up soon as poss. let me know wat u think
C5 RS6
MCB
RE: hademade exhaust!
Post by MCB » Sat May 26, 2007 5:34 pm
Lets have a look then...
S4B5 Avant
HobsonS4
Post by HobsonS4 » Sat May 26, 2007 6:03 pm
if my fu**ing computer doesn't start workin im guna throw the thing through the window!
C5 RS6
shineydave
Post by shineydave » Sat May 26, 2007 6:10 pm
Dave
HobsonS4
Post by HobsonS4 » Sat May 26, 2007 6:30 pm
cheers Dave u saved my computer from certain death.
C5 RS6
S4TAN
Post by S4TAN » Sat May 26, 2007 7:10 pm
Wow! Good work Hobson ... sounds great too. Is there any performance gain?
Deus ex machina
HobsonS4
Post by HobsonS4 » Sat May 26, 2007 7:23 pm
i expect there will be a slight increase in power, there has to be, the gases are flowing a lot more freely, i cant say as i can notice it though, the sound itself makes the job worth while
C5 RS6
GrahamS4
Post by GrahamS4 » Sat May 26, 2007 7:37 pm
So the only point that exhaust isn't just a pipe is the main cats or are those gutted too?
Present: 2010 Ice silver B8 S4 s-tronic saloon (standard)
Past: 1998 Agate grey B5 S4 saloon (MRC tuned)
Hers: 2011 Volcano red 8P A3 Sportback 2.0 TDI 170 sport quattro
shineydave
Post by shineydave » Sat May 26, 2007 8:37 pm
gutted pre cats. main cat and middle box still present
Dave
saf
Post by saf » Sat May 26, 2007 9:53 pm
Have you got a pic of what you done to the back box?
HobsonS4
Post by HobsonS4 » Sun May 27, 2007 11:21 am
saf wrote:Have you got a pic of what you done to the back box?
u have lost me there saf! there is no back box anymore
C5 RS6
saf
Post by saf » Sun May 27, 2007 11:28 am
Sorry I want paying attention.
Is the whole exhaust made from before by yourself? Or just the mod that you done?
If its the case that youve modified another exhaust, what was it before you chopped off the box?
Lookis like it was a single exhaust? What brand? or completely home made?
C-24
Post by C-24 » Sun May 27, 2007 11:28 am
Hobson,
The exhaust looks superb, how did you do that ?
S4 avant imola yellow
Sportec remap 320hp / 500nm
Brembo GT-brakes
RS4 suspensions
HobsonS4
Post by HobsonS4 » Sun May 27, 2007 11:36 am
i have a hangover and your confusing me saf! the back box splits from the mid section there is a sleeve that slides over the pipes holding them together there is no cutting involved, jus undo the 2 bolts on the sleeve that holds the mid to the back section. before i did this my exhaust was standard the pipe is 2.5" standard.
C5 RS6
HobsonS4
Post by HobsonS4 » Sun May 27, 2007 11:43 am
C-24 wrote:Hobson,
cheers dude.
its quite simple if u have the tools and equiptment. stainless tube, stainless bends and a tig welding set, i removed the original back box and basically used the bends and tube to create 1 piece starting and finishing at the same points as the standard box. measured where all the hanging brackets were and made these with some 12mm bar.
i hope this sort of explains it
C5 RS6
