rs4 recaro into s4 saloon
I know its been asked before but cant find post,will a rs4 interior go into a s4, mainly the rear seats and rear door cards.
RE: rs4 recaro into s4 saloon
Rear seats have the wrong catch arrangement for the Saloon.
- Top Gear
I'm giving it a go very soon. For the upper, the latches for the seat backs will need to be moved and re-welded on the car. If that doesn't work out, i'm going to take the rears and my original cloth rears to a local upholsterer and get them to make me a frankenstein seat (saloon bases with recaro foam and leather grafted on).
Good luck with that, let us know how you get on.
Does anyone have any EKTA type piccies of the difference ?
And do the difference vary - pre/post facelift etc. ?
- Top Gear
Even if it takes a spirited session with a nail gun and many rolls of gaffer tape to hold them in place... they are going to fit!
- Top Gear
- Top Gear
Well, i'm nearly there. Got some 4.7 Ohm resistors off fleabay and cleared the airbag warning code using Vagcom. Sorted!
As for the rears, it looks easier than I thought. The base is a straight swap. The uprights bolt in the same way as the saloon.
There are only two issues.
1) The side bolsters for the avant don't have an 'overhang' meaning there will be a gap of about 2"x3" underneath the seatbelt at the back. I can live with that.
2) The latch arrangement is different, but it should be a much easier job than I had earlier anticipated (welding/etc.). The saloon latch will come off with a couple of torx bolts.
Should be a piece of
to fabricate something to bolt into it's place. When I get it done, i'll post up the dimensions incase someone else fancies taking on the task. Reckon a local welders should be able to sort it out for chump change.
- Top Gear
Users browsing this forum: No registered users and 61 guests
