Help - not running right
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Chameleon
Post by Chameleon » Sun Apr 29, 2007 2:27 pm
Just like to say hello as I'm new to this forum.
Right now on to the serious stuff. I've just renewed the secondary water pump on my 1999 s4 following the instructions in the "How to" sticky. Everything went ok - job done until I've started the engine. Its running very lumpy so I did an engine scan and the following codes came up.
17952 - throttle actuation potentiometer signal too high
16622 - turbocharger boost sensor (A) circ high input (G31)
17580 - throttle actuation potentiometer sign 2 signal too low
16497 - intake air temp circ high input
When I removed the intake manifold I disconnected all of these wires. Can anyone tell me if this is the norm until the ECU resets these circuits on idle. If anyone can provide any advice on these problems it would be much appreciated as I don't want to attempt driving the car as it is
S4TAN
RE: Help - not running right
Post by S4TAN » Sun Apr 29, 2007 4:07 pm
Have you tried disconnecting the battery for a few minutes and letting the ecu reset itself? Obviously i assume that you plugged in all of the leads you disconnected ... and in the right place? (did you get the 2 plugs mixed up that connect to the MAP sensor and throttle body valve? ...)
Oh, hello and welcome ... :lol:
Deus ex machina
GrahamS4
Post by GrahamS4 » Sun Apr 29, 2007 4:23 pm
Have you reset the codes and had them return?
Present: 2010 Ice silver B8 S4 s-tronic saloon (standard)
Past: 1998 Agate grey B5 S4 saloon (MRC tuned)
Hers: 2011 Volcano red 8P A3 Sportback 2.0 TDI 170 sport quattro
grizz
Post by grizz » Sun Apr 29, 2007 4:23 pm
Hi & welcome , you cant get the plugs wrong the way round . Try clearing the codes and try again . All the best grizz
Unit 20
0151 3366888
S4TAN
Post by S4TAN » Sun Apr 29, 2007 4:25 pm
i did wonder about that - i never tried it to see if they would go the wrong way, but they do look similar ...
Deus ex machina
Chameleon
Post by Chameleon » Sun Apr 29, 2007 5:54 pm
Cheers Guys
Just cleaned all the connections and reset the codes. Started it up - still sounded a bit lumpy at first but soon sorted itself out. Just gave it a road test and everything seems as it should be.
Great site
Users browsing this forum: Google [Bot] and 28 guests
