solar sunroof
solar sunroof
do you have to do anything to make it work ie so car is cool when you return to it?
thx chaps
thx chaps
RE: solar sunroof
You do not have to do anything mate.
if comes on automatically.
Baz
Baz
Past: Noggy 2000 B5 S4
Azure Blue 2000 Oettinger B5 S4
Mugello RS6 *STOLEN* RN52 UXB
Avus Oettinger A3 2.0T
Misano Oettinger C5 RS6
Phantom Oettinger C6 A6 Sline Avant
Present: RS7 Panther Black
Porsche Cayenne
C7 Avus silver avant 2.0 tdi ultra
Porsche Cayenne
RE: solar sunroof
Yes but its absolutely useless whether it works or not, as all it does is power the fan and circulate warm air, so has very little cooling effect to the cabin.
RE: solar sunroof
ah ok, thought it got the aircon to kick in, thats cr@p considering how much it cost as an option
RE: solar sunroof
I thought that too. Not like the "REST" button on Mercs and modern top end VAG cars where the climate control keeps running and reuses the cool air from the aircon and acutally maintains the cabin temperature for up to half an hour after the engine is turned off.
To be honest, the clear glass sunroof option is far more valuable than the solar one.
At least it does what it says on the tin
RE: solar sunroof
Actually I believe the solar roof can be turned on or off, I think you press the recirulation air con button before
switching the engine off. I agree 'cooling' does not work fantastically - but it does make a noticeable difference.
I'd order one again..
RS6 Avant
RE: solar sunroof
I've asksed this before ... but still dont get it .... how do you know its actually working ? What are the settings to get it working i.e. does the car have to be locked, or do you have to press the recirc button, do the vents need to be open etc.
Works for me, but in order to benefit from it on hot days make sure the rear passenger vents are open so the air circulates.....I also initially had the problem of windscreen condensation which was rectified by York Audi when they fitted a replacement temp switch, a problem which is well documented by Audi and known of by most dealers....
Dave
Dave
einer: Nogaro Blue B6 S4
zwei: Mugello Blue C5 RS6
drei: Magnetite C63 AMG
vier: Ibis White RS5
fünf: Phantom Black B7 RS4 - Currently
