Having a few problems bleeding my clutch after replacing the slave cylinder. Im using an eazi bleed which I have attatched to the reservoir, made sure the clutch pedal is pulled right back and plonked it in 3rd gear as per workshop manual, but when I open the bleed nipple nothing comes out, its as if something is blocking it.
Am I doing something wrong or could it be a faulty clutch master cylinder?
thanks in advance
Help Bleeding Clutch
RE: Help Bleeding Clutch
Anyone?
Ok, finally got the stupid thing to bleed but to no avail, have a sort of pedal but absolutely no clutch.
Having now replaced the friction plate, pressure plate, release bearing and slave cylinder, the only thing I have not replaced now is the clutch master cylinder so just ordered one up.
Just wondered if anyone has any tips on fitting it (looks pretty straight forward but then most things do until you start it
Users browsing this forum: Google [Bot] and 36 guests
