Leak test done...
Leak test done...
I've just done a leak chaeck on my intake system and I can hear air bubbling through the crackcase and oil.
Am I right in thinking this is most likely a problem with the one way valves on the spider pipe?
Help please!!
Help please!!
Mark
RE: Leak test done...
isn't it just the cranckcase breather - as in to relieve pressure?
Some air is bound to escape past the rings - especially if the engine has been sat for a long time (overnight) and the oil has drained back down to the sump.
Try it again after a run, see if anything changes.
Wanted: C5 RS6 Avant
Audis are cheaper than women, and when they finally leave they don't take your kids and half your stuff....
although smack either one about and the police turn up
I thought that was normal Mark.
Present: 2010 Ice silver B8 S4 s-tronic saloon (standard)
Past: 1998 Agate grey B5 S4 saloon (MRC tuned)
Hers: 2011 Volcano red 8P A3 Sportback 2.0 TDI 170 sport quattro
Yep, normal.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
yo S4TAN u shud be used to bubbling from dwn below..there,s a hell of alot of lava flowing where u come from..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
I remember you posting a while ago that your car wasn't too happy
How do you think you blocked the breather system?
Mine seems fine at the moment after my attempt though I think I was putting about 30+ psi into the system.
I had removed the oil filler and could hear the oil going "blub blub blub"
Is is normal to hear air passing the butterfly or have a likely got a leak around the TBB? I going to get my self a Samco TBB and F hose so I'll strip and inspect all these soon.
Mark
Sounds fine to me from what you have said. I would think there would be lessMarkB wrote:I remember you posting a while ago that your car wasn't too happyHow do you think you blocked the breather system?
blow-by if the engine was up to temperature. Forged pistons tend to expand a
little when they get hot. My car now has 110k miles. Coupled with my little kinked
hose 'accident' I am going to look into getting it re-ringed. Any ideas from the
mechanics amongst on how long this would take?
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
- shineydave
nope, you need access to the conrod end caps to get the pistons out, you might be able to do it with just a bottom end strip though, ie, sump off. i'm sure someone with more experience will be along shortly to put me right
**edit**
looking at the engine exploded diagrams it looks like the gearbox probably needs to come out to remove the crankshaft
**edit**
Dave
the pistons have to come out from the top which means the heads have to come off..now if you took off the heads in situ then the sump you should be able to undo the big-end caps and push out the pistons and rods..but its so much work you just mite aswell pull the engine out and do it properly..
020 83353032
020 83353032
- shineydave
can you not remove the crank and drop them out of the bottom then?
Dave
