They are easy to fit, but running on snow etc I would rather have a softer setup. Should give more grip.reserves wrote:What's the model number of the larger ones? How hard is it to fit / get these fitted. I'm in the alps for the season so MRC is out of the question...
H&R ARBs or AWE DTS?
- GrimReaper
to save a new topic does anyone know the length of the rear drop links as sure its plastic so want to replace it incase it breaks when uprating the ARB's. What about the fronts are they prone to breaking or aree they stronger ( sure i read some where they were metal)
KO4's Full Bilstein suspension, MRC custom remap Dual milltek, de pre-catted & custom Decats Forge DV's H&R ARB's, 18" RS4 Reps
Cayenne calipers B5 RS4 discs PICS: http://s8.photobucket.com/albums/a4/sjy666/Audi%20pics/
http://cgi.ebay.co.uk/H-R-rollbars-Audi ... dZViewItem
Are these the ones? Are these the larger ones that u reccomended?
the stock plastic droplinks are fine - I run them on the thick rear arb with adapters to to give you a 3rd or 4th stiffer setting.
I cannot reommend the stiff arbs - if you only do one mod to the handling of the car, get them on. SPend 10 minutes adjusting th esnub mount to stop some engine/box moevement.
http://www.MRCtuning.com
Snub mount adjustment! first time I've heard that. Please tell...Doug_S2 wrote:the stock plastic droplinks are fine - I run them on the thick rear arb with adapters to to give you a 3rd or 4th stiffer setting.
And I assume you can't recommend the ARB's 'enough'
Mark
Thanks guys, I am liking the idea of these......
I feel comfortable with my car up to 7/10th's, after that the handling makes the whole thing less fun....these arbs seem to be the answer.....I was likely to do DTS anyhow.
2000 B5 S4 facelift, sadly missed...enjoying the 2005 A2 TDi Special Edition though!
Can't remember exactly how bad body roll was pre-ARB's, but they transform the handling of the car, I've still got standard dampers fitted but the ARB's are enough to inspire confident cornering
...go for the thick bars on full-hard settings
Milltek dual cat-back, gutted downpipes, ECS Tuning stage3 brakes, MRC custom map, H&R ARBs.
- 5th Gear
These are the thicker of the two available S4 anti-rollbars kits. These are in stock for next day delivery. If you order directly I will throw in the carriage.stevieyid wrote:http://cgi.ebay.co.uk/H-R-rollbars-Audi ... dZViewItem
Give me a ring when you are ready
Philip
01437 563793
Users browsing this forum: Google [Bot] and 45 guests
