My S3 Boost Curves - Stock vs. Revo mode
Rabs
Re: My S3 Boost Curves - Stock vs. Revo mode
Post by Rabs » Tue May 20, 2003 7:54 pm
How much is it ? [img]images/graemlins/s3addict.gif[/img]
DuncS3
Post by DuncS3 » Tue May 20, 2003 8:35 pm
50 + VAT
DuncS3
Post by DuncS3 » Tue May 20, 2003 10:45 pm
Well on tonights logging timing 6 was chucking up corrections of 6 and 7.5.
Switched to timing 5 and things seem okay, but I did a day of logging (albeit in the wet) on Friday and timing 6 was okay. Not sure if its my car or what but timing 5 is the SUL petrol setting I thought and I run Optimax and Millers...
almost 350 nM on tonights run though on low boost 9/timing 5 which is pretty good, and nearly up 10nm on the 'old' high boost settings we have logged previously.
boost and torque graphs to follow tomorrow from Simon
Dunc [img]images/graemlins/s3addict.gif[/img]
Riz_RS4
Post by Riz_RS4 » Sun Jul 27, 2003 10:26 am
what does that mean? so what is the correct timing for optimax and millers? timing 5 or 6? lowboost or highboost?
What happens if you put the ignition timing too high, i.e. highboost 9 timing 9?
Cheers for the info [img]images/graemlins/clap.gif[/img]
Image I`m just a hardcore petrol head :)
tartan_rob
Post by tartan_rob » Fri Sep 05, 2003 1:33 pm
If you use channels 115 - 120 and dump the values into EXCEL you'll be able to see exactly what the turbo is doing and what the ECU is easking it to do. As a rule, the ECU will reduce boost pressure higher up the rev range, most chip's stop this. Get the channels (actual boost, requested boost, specified boost, wastgate angle, throttle angle, throttle actuator angle) mapped along with Torque, speed and revs and you'll know exactly what is going on.
2017 Kawasaki Z1000
2014 RS6
2014 S1
Users browsing this forum: No registered users and 19 guests
