To VAG-Com users, FATS times database for the Euro S4s
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
MarkB
Post by MarkB » Wed Oct 04, 2006 3:59 pm
Here we go...
edit, wasn't on topic so see here. http://www.rs246.com/index.php?name=PNp ... 436#137436
Mark
si_hill
Post by si_hill » Thu Oct 05, 2006 9:38 pm
out of interest do you guys have someone starting and stopping the logging for you or do you do this yourself whislt driving? I have found you need a very long straight to carry out this FATS log. I tried it the other night and ran out of road, redline in 3rd is shifting pretty fast. Any tips appreciated.
MarkB
Post by MarkB » Thu Oct 05, 2006 9:56 pm
Leave it logging. Files don't get that big
Mark
Nige_RS4
Post by Nige_RS4 » Thu Oct 05, 2006 10:16 pm
I found this out too, whilst accelerating hard in 3rd round a bend in the S4. Things happen so much quicker in the RS, you only need half the distance to do a 3rd gear run.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
oliew
Post by oliew » Fri Oct 06, 2006 2:23 pm
i normally have my laptop with the cursor over the marker button, when i decide i can do my 3rd gear run i just reach out my hand and click the buttonso i get a number in the first column to find it later :)
S4 B5 - MRC
Nige_RS4
Post by Nige_RS4 » Fri Oct 06, 2006 7:29 pm
The spacebar acts as a marker trigger too!
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
buzzard
Post by buzzard » Sat Oct 07, 2006 9:48 am
3rd gear fats is quick enough on local roads
i think i'm right in saying that dippy also did it in 4th gear earlier in this subject --yes 4th!!!
he was probably doing 125 ish
oliew
Post by oliew » Sat Oct 07, 2006 1:58 pm
Nige, thats interesting, learn somethin every day :)
ta
S4 B5 - MRC
smurfbus
Post by smurfbus » Sat Oct 07, 2006 2:46 pm
pretty bored so I dig up my best run about a year ago. It was 0 C and I ran 100oct with 1.7bar to 1.5bar. Straight K04's, CATs and #36 injectors at 5bar and homebrew stg1 software.
Since that I installed rs4 gearbox so I cant compare my times anymore.
block 003 and CFs block 020
837,21 3720 146,22 100 22,5 836,92 1,5 1,5 1,5 1,5
837,82 4160 218,61 100 8,30 837,52 5,3 8,3 6,0 4,5
838,46 4760 246,94 100 9,80 838,15 5,3 8,3 6,0 4,5
839,14 5320 259,78 100 11,3 838,80 6,0 7,5 4,5 4,5
839,85 5880 269,50 100 14,3 839,49 5,3 6,8 3,8 3,8
840,60 6360 278,42 100 15,0 840,22 5,3 6,8 3,8 3,8
841,35 6840 277,44 100 16,5 840,97 5,3 6,8 3,8 3,8
MarkB
Post by MarkB » Sat Oct 07, 2006 5:53 pm
smurfbus wrote:pretty bored so I dig up my best run about a year ago. It was 0 C and I ran 100oct with 1.7bar to 1.5bar. Straight K04's, CATs and #36 injectors at 5bar and homebrew stg1 software.
When you say homebrew software... How?
Mark
smurfbus
Post by smurfbus » Sat Oct 07, 2006 7:32 pm
well, running stg1 code with stg3 is considered homebrew. I just adjusted fueling channels to compensate maf/fpr/injectors changes.
MarkB
Post by MarkB » Sat Oct 07, 2006 8:42 pm
Cool. I see now.
Do you have info on what channels do what? I'm interested in changing things like fuel, boost and timing...
Mark
smurfbus
Post by smurfbus » Sat Oct 07, 2006 8:59 pm
http://forums.fourtitude.com/zerothread?id=1618056
I would first buy wideband airfuel meter before changing any fueling parameters and even then you need to fully understand what you do. Its too easy to blow your engine making wrong adjustments.
MarkB
Post by MarkB » Sat Oct 07, 2006 9:16 pm
smurfbus wrote:http://forums.fourtitude.com/zerothread?id=1618056
Great I'll take a read...
I make your fats time under 3 seconds :rocker:
Mark
SimonS4MTM
Post by SimonS4MTM » Thu Nov 30, 2006 10:43 am
So i finaly got around to doing my first FATS runs.
I logged channel 002.
My first time was 5.02, and my second time was 5.14.
How does that sound?
Return to “DTC / VCDS”
