Steering wheel removal
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
MarkB
Post by MarkB » Thu Aug 24, 2006 10:19 am
Hi all
Tried to remove the steering wheel on my S4 yesterday and got as far as the bolt that holds it on. Anyone know what size splined bit I need?
Also what is the large cast lump of metal that is mounted on soft rubber behind the airbag with the large hole through it for? Bad discription I know :?
steering wheel bolt.JPG (79.16 KiB) Viewed 1218 times
Mark
QuantumJohn
Post by QuantumJohn » Thu Aug 24, 2006 10:57 am
Mark,
I think it is 16mm spline but it could be 18mm. Can't remember exactly.
No idea what the metal lump does. It has 3 screws holding it on to the wheel and is quite heavy. Perhaps for the airbag to sit against as every force has an opposite reaction?
John
MarkB
Post by MarkB » Wed Sep 06, 2006 2:51 pm
Bump
Anyone know where I can get a tool from to remove my wheel. Both the local Motor Factors don't stock spline drives!
Mark
CliveH
Post by CliveH » Wed Sep 06, 2006 4:08 pm
Shineydave knows exactly what the spline tool is to remove the wheel.
The metal block is what makes the horn's contacts meet - also a bad description :bash:
Clive
MarkB
Post by MarkB » Wed Sep 06, 2006 9:02 pm
Lets hope he see's this then as I might have to get one via mail order...
Mark
CliveH
Post by CliveH » Wed Sep 06, 2006 9:10 pm
He'll be along shortly...
Clive
shineydave
Post by shineydave » Wed Sep 06, 2006 9:20 pm
just waiting for the adverts on itv2 then i'll nip into the garage and have a look
ChipHazzard
Post by ChipHazzard » Wed Sep 06, 2006 9:21 pm
Dont forget to mark the steering wheel and spline before removing
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
shineydave
Post by shineydave » Wed Sep 06, 2006 9:32 pm
right, the tool we used is a 12 spline and it's 12.0mm across the splines. it's marked on the shaft as "Draper 12" but i don't know if that refers to the number of splines or the AF measurement. if it makes it easier it's a tool i bought donkeys years ago for removing cylinder heads on ford pinto SOHC engines
QuantumJohn
Post by QuantumJohn » Wed Sep 06, 2006 10:47 pm
MarkB
Post by MarkB » Thu Sep 07, 2006 9:39 am
shineydave wrote:right, the tool we used is a 12 spline and it's 12.0mm across the splines. it's marked on the shaft as "Draper 12" but i don't know if that refers to the number of splines or the AF measurement. if it makes it easier it's a tool i bought donkeys years ago for removing cylinder heads on ford pinto SOHC engines
Thats great thanks Dave. I stand a chance of borrowing one of those off someone at work...
Mark
MarkB
Post by MarkB » Thu Sep 07, 2006 4:00 pm
Would this do the job? http://cgi.ebay.co.uk/11Pc-1-2-Drive-Lo ... dZViewItem If I can't borrow anything...
Mark
shineydave
Post by shineydave » Thu Sep 07, 2006 6:08 pm
yup, that should work a treat, plus u got the other sizes as well for future use
springfield
Post by springfield » Thu Sep 07, 2006 8:37 pm
I also have a set of them again bought donkeys ago nevr get rid you never know when they will come in handy.
Imola Avant,Carbon,Bose,MRC Re Map,Hyperboost DV.s.
BMW E30 318iS.
MarkB
Post by MarkB » Fri Sep 08, 2006 6:20 pm
Well I bought a set of splines... Sure enough it was 12mm that fitted, thanks ShineyDave. Removed the wheel and cowling, then started to look for the rattle thats been bugging me for months. Found it! Nothing to do with the wheel or column... it was the panel under the dash! not been fitted back properly and the metal clip by the centre tunnel was the rattle!! Happy now all quiet. :) and I now know how to take the wheel off ;)
Mark
