Anti-Roll Bars for the S4
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
rsdreamer
Post by rsdreamer » Thu Jul 13, 2006 8:25 am
Hi all.
Go for 32 / 21's with some adjustable links for the rears.
My oem links broke on my first trackday, but the replacement adjustables are doing very well indeed.
Don't forget, arb's control body roll, coilovers control stiffness.
With the rear arb, the hole to the front of the car = soft setting, hole to the rear of the car = hard setting, (least body roll).
rsdreamer.
:yellowrs4:
SimonS4MTM
Post by SimonS4MTM » Thu Jul 13, 2006 9:11 am
I am struggling to see how an adjustable arb link will effect the arb stiffness.
Would someone kindly explain please?
MarkB
Post by MarkB » Thu Jul 13, 2006 9:13 am
Moving forward or backwards would efect the turning moments against the bar so adjusting the amount of twist put on the bar. I can't imagine it would make a massive difference though
Mark
s4woody
Post by s4woody » Thu Jul 13, 2006 9:18 am
Smoothes out suspension to help balance out cornering,and i believe it releases all the preload tension of the arb,s..plus they dnt flex..
GARTH ROAD MOT CENTRE LTD
020 83353032
SimonS4MTM
Post by SimonS4MTM » Thu Jul 13, 2006 10:23 am
MarkB wrote:Moving forward or backwards would efect the turning moments against the bar so adjusting the amount of twist put on the bar. I can't imagine it would make a massive difference though
That is the holes on the ARB, yes I can see how that effects the stiffness.
SimonS4MTM
Post by SimonS4MTM » Thu Jul 13, 2006 10:25 am
s4woody wrote:Smoothes out suspension to help balance out cornering,and i believe it releases all the preload tension of the arb,s..plus they dnt flex..
Surely that will put a pre-load on the arb, leaning the car one way will increase the twist on the arb, but leaning the car the other way will release the pre-load to eventually reaching a point of equilibrium before twisting the shaft in the other direction. Surely that cannot be good for handling?
MarkB
Post by MarkB » Thu Jul 13, 2006 10:27 am
Ah yes sorry. I re-read your post... But as Simon says they can remove pre load, but also if they are made longer or shorter depending on the angle this then puts it in relation to the bar and the angle the bar is then at you are changing the force against the bar
Mark
MarkB
Post by MarkB » Thu Jul 13, 2006 10:28 am
You want no twist on the bar when the car is flat and level. Unless you are Oval Racing!
Mark
SimonS4MTM
Post by SimonS4MTM » Thu Jul 13, 2006 11:05 am
MarkB wrote: You want no twist on the bar when the car is flat and level. Unless you are Oval Racing!
But if you change the length of one of your arb links, this will put twist on the bar.
MarkB
Post by MarkB » Thu Jul 13, 2006 11:18 am
You would want the change the length of both and keep the pre load off the bar
Mark
SimonS4MTM
Post by SimonS4MTM » Thu Jul 13, 2006 11:27 am
MarkB wrote:You would want the change the length of both and keep the pre load off the bar
If you change the length of both, then how is that changing the pre-load on the bar?
Sorry for all the questions!
s4woody
Post by s4woody » Thu Jul 13, 2006 12:01 pm
i think if the links are made longer that will alter the angle of the arb which will change the reaction time surely..or even the leverage effect..you dnt see many racing cars with plastic suspension parts and i,m sure that even if we dnt quite grasp the reasons behind it they work better than oem..
020 83353032
SimonS4MTM
Post by SimonS4MTM » Thu Jul 13, 2006 12:05 pm
s4woody wrote:i think if the links are made longer that will alter the angle of the arb which will change the reaction time surely..or even the leverage effect..you dnt see many racing cars with plastic suspension parts and i,m sure that even if we dnt quite grasp the reasons behind it they work better than oem..
Yes, I can see the benefit of fitting stiffer links, just cant see the point in making the length adjustable.
s4woody
Post by s4woody » Thu Jul 13, 2006 12:07 pm
well the way i design them is so that u can adjust the taper high enuf to miss the driveshaft when changing to the hardest setting..well that was the idea anyway..
020 83353032
MarkB
Post by MarkB » Thu Jul 13, 2006 12:58 pm
It all down to the length and the leverage. Hard to explain in words, maybe someone could do a drawing.
Mark
Users browsing this forum: No registered users and 81 guests
