Just checked my car with vag com..
1 Fault Found:
17862 - Exhaust Gas Temp Sensor 1 (G235): Short to Ground
P1454 - 35-10 - - -
easy to fit? prices? any ideas? lol
would that also explain the seat of the pants ometer feeling a slight lack of power or should I be checking for MAF problems too? (none logged as errors)
Cheers,
a
EGT sensor?
EGT sensor?
98/Missano/Bose/Carbon
RE: EGT sensor?
theres one screwed into each of the turbo exhaust housings real PITAs to reach
going by the "Sensor 1" that looks like the passenger side and as clubsport says that is the worst one to get at
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
911 Turbo Remapped. Hated it
RS6 V10 700BHP crazy
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
I changed my EGT about a month or so ago. I'm sure mine was sensor 1 and that was the easy one to do (drivers side).
Easiest way to check is, follow the wiring from the drivers side egt and disconnect it. Start the car and run vag com again, this time (if it is this sensor) the fault code will still come up but it will say something else instead of 'short to ground'.
If however, you have TWO egt 235 sesnor faults....then its the harder one to replace. But im fairly certin drivers side or from front view, the left side is bank one and the passenger side (or right hand side from front view) is bank 2.
HTH,
Dan
HTH,
Dan
A4 2.5 V6Q B6 Avant
