EGT sensor?
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
fade2grey
EGT sensor?
Post by fade2grey » Sat Jun 17, 2006 3:30 pm
Just checked my car with vag com..
1 Fault Found:
17862 - Exhaust Gas Temp Sensor 1 (G235): Short to Ground
P1454 - 35-10 - - -
easy to fit? prices? any ideas? lol
would that also explain the seat of the pants ometer feeling a slight lack of power or should I be checking for MAF problems too? (none logged as errors)
Cheers,
a
98/Missano/Bose/Carbon
dummi
RE: EGT sensor?
Post by dummi » Sat Jun 17, 2006 3:53 pm
theres one screwed into each of the turbo exhaust housings real PITAs to reach
clubsport
Post by clubsport » Sat Jun 17, 2006 4:26 pm
The boys at MRC found that one of mine had packed up....fortunately it was the offside or rhd drivers one, managed to change it in 15 mins. The one on the other side is the more difficult one......
Vag com should be able to tell you which one is causing you problems....
Paulm
Post by Paulm » Sat Jun 17, 2006 4:37 pm
going by the "Sensor 1" that looks like the passenger side and as clubsport says that is the worst one to get at :(
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
911 Turbo Remapped. Hated it
RS6 V10 700BHP crazy
fade2grey
Post by fade2grey » Sun Jun 18, 2006 9:53 am
bugger!
ConvictS4
Post by ConvictS4 » Mon Jun 19, 2006 5:22 am
I have been through same recently (there's a thread in here somewhere on it). Golich seems to have the most recent hands on experience.
2003 Daytona Grey RS6 Avant
2007 Daytona Grey B7 RS4 Cabrio on order
About as west as you can go in the colony without getting your feet wet.
Tdi_dan
Post by Tdi_dan » Fri Jun 30, 2006 10:50 am
I changed my EGT about a month or so ago. I'm sure mine was sensor 1 and that was the easy one to do (drivers side).
Easiest way to check is, follow the wiring from the drivers side egt and disconnect it. Start the car and run vag com again, this time (if it is this sensor) the fault code will still come up but it will say something else instead of 'short to ground'.
If however, you have TWO egt 235 sesnor faults....then its the harder one to replace. But im fairly certin drivers side or from front view, the left side is bank one and the passenger side (or right hand side from front view) is bank 2.
HTH,
Dan
A4 2.5 V6Q B6 Avant
