ABS and ESP Lights
1.8 I4 20v turbo - 207bhp
1.8 I4 20v turbo - 222bhp
Gee
ABS and ESP Lights
Post by Gee » Fri Jan 20, 2006 2:18 pm
On my drive to work today both the ESP and ABS lights came on the dash. I switched off the ignition and on again and the OK light came on but the ESP and ABS lights stayed on.
Anyone have any idea as to why this would happen all of a sudden?
david7m
RE: ABS and ESP Lights
Post by david7m » Fri Jan 20, 2006 2:21 pm
My ESP light came on when one the motion sensors was faulty. I think there is two sensors to detect the direction of the car, one from front to rear and another left to right. They work together in conjunction with the ABS to operate the traction control.
Mine was replaced under warranty ;)
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat Image
TarmacTerrorist
Post by TarmacTerrorist » Fri Jan 20, 2006 2:29 pm
You could also check to see that the battery is not it's way out.
esp and abs suck loads of power on start up, if the battery is failing it can sometimes get the car started but will not fire up abs or esp.
Too much is bad.
Plenty is better.
Gee
Post by Gee » Fri Jan 20, 2006 5:28 pm
I've noticed that my rear brake discs are close to needing replaced could this cause any probs with the above?
Is it just a case of getting a VAG Com check done to find the problem?
DuncS3
Post by DuncS3 » Fri Jan 20, 2006 6:59 pm
Get a VAG COM check - it could be anything but if those lights are on you should have an error logged
Dunc
Firbee
Post by Firbee » Fri Jun 16, 2006 12:15 am
I've just had exactly the same problem, the cause turned out to be a failed speed sensor that provides input to the esp. All up the stealership billed me £202 inc VAT to sort it. £55 to confirm problem, £41 for the part and the rest for labour!!
Misano RS4 (B5), MRC Custom Map , Quick shift, Milltek Exhaust and Downpipes, B7 Front Brakes
jons3
Post by jons3 » Fri Jun 16, 2006 8:48 am
my ABS/ESP lights kept coming on, but always went out again when you turn the engine off and on again. Ended up being a front to back motion sensor according to Audi. £100 for the part, £100 labour.
seems to have fixed it, but I only had it done earlier this week
shineydave
Post by shineydave » Mon Jul 17, 2006 11:46 pm
mine have just come on. any idea where the sensor is in the car?
davidhodgkinson
Post by davidhodgkinson » Tue Jul 18, 2006 8:39 pm
On the s3 the lateral sensors are under the steering wheel dave
Audi 80, Audi Coupe, Audi A3 1.8T All gone :-(
2001 Audi S3 :-) Lots of fun
Honda FireBlade
shineydave
Post by shineydave » Tue Jul 18, 2006 9:21 pm
cheers, i'll have a look on etka and see if i can identify it.
shineydave
Post by shineydave » Tue Jul 25, 2006 10:56 pm
turned out to be a faulty MAF eventually
Return to “S3 (Typ 8L) 1999-2003”
Users browsing this forum: No registered users and 20 guests
