Front Speaker replacement
Sounds like my left front speaker is going. Does anyone know if it's a straightforward job to replace?
Mike
Mike
RE: Front Speaker replacement
Yes it is, I did it myself last weekend.
There are 2 screws on either end of the top of the door panel, then remove the screw under the door pull, prise the small plastic section out (downwards) to reveal 2 more screws. Remove these and the entire door panel will pull upwards. There are 3 electrical cables to unplug and the central locking vacuum pipe. The speaker is held on with 3 screws.
note - all screws are philips/posidrive type.
HTH
HTH
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
I replaced it like for like, but having now seen the speaker, the quality is actually quite poor (I assume you've got BOSE too).
Maybe there is a recommended upgrade out there that doesn't involve any cutting, drilling or bodging!
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
- 5th Gear
- SimonS4MTM
- Top Gear
Hello all,
I just did this in mine...
I have gone for a mild install... not OTT.
Got the bits from CarAudio Direct online.
I got a set of Rainbow SLX 230 Deluxe speakers w/ external crossover. I got the door adapters - again from CarAudio Direct...
Took a bit of fiddling to fit - but what a difference. Since I have added an amp and WOW - they sound great!
ONLY CONSIDER DOING THIS IF YOU HAVE A NON-BOSE SETUP. Otherwise you will HAVETO replace the amps etc.
Removing door panels can be found here:
http://www.audiworld.com/tech/int13.shtml
More on my audio install here - including links to the bits I bought etc:
NB: I got the wrong speakers first time round!!
http://www.audi-sport.net/vb/showthread.php?t=22423
Besta Luck!
Besta Luck!
- 5th Gear
This is what I am running in my car up front..
Focal: 130V1 - 13cm component speakers
Product Code: FOCAL-POLYGLASS-130V1
Our Price: £135.00
Product Features
2-way 13cm (5.25") component speakers
Voice Coil: 25mm.
Motor: 85mm.
Tweeter: Orientable aluminium inverted dome
Plug&play quick connection system.
Max. power: 120W.
Nom. power: 60W.
Sensitivity: (2,83 V/1m) : 91dB.
Frequency response: 75Hz-28KHz.
Mounting depth: 61.3mm
Grilles supplied.
Sold in pairs
http://caraudiosecurity.com/shop/produc ... urer_id=55
Our Price: £135.00
Product Features
Voice Coil: 25mm.
Motor: 85mm.
Max. power: 120W.
Nom. power: 60W.
Grilles supplied.
Sold in pairs
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Car is on Lock down
What's different about the BOSE setup that makes it difficult to fit aftermarket speakers?
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
- 5th Gear
I didn't have the bose setup in my car, but my mate did. wasn't any harder to fit the new system. but we both did fit new front and rear speakers and sub new head unit one 5 chennel amp. Didn't use any of the original wiring ( speaker or power) was better to start again........
This is the sub box that I use in my car...
Auto Acoustics
http://www.autoacoustics.com/sbo-aa4.htm
Auto Acoustics
MING BLUE AUDI S4
Car is on Lock down
Car is on Lock down
Thanks Brett - did you replace all 4 main speakers with the same type (or are the rear speakers a different size on the saloon?)
Anyone replaced the rear speakers on an avant?
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
- 5th Gear
I fitted theses to my car because it was a saloon.
Focal: 690CV1 - 6"x9" speakers
Product Code: FOCAL-POLYGLASS-690CV1
Our Price: £129.99
Product Features
2-way 6"x9" (130x180mm) coaxial speakers
Voice Coil: 32mm.
Motor: 90mm.
Filter 6 dB/octave
Max. power: 160W.
Nom. power: 80W.
Sensitivity: (2,83 V/1m) : 93dB.
Frequency response: 50Hz-20KHz.
Mounting depth: 93.1mm
Grilles supplied.
Sold in pairs
But my mates car is an advant so he fitted theses.
Focal: 130CV1 - 13cm speakers
Product Code: FOCAL-POLYGLASS-130CV1
Our Price: £94.99
Product Features
2-way 13cm (5.25") coaxial speakers
Voice Coil: 25mm.
Motor: 72mm.
Tweeter: TN 47 C rotational.
Filter 6 dB/octave
Max. power: 120W.
Nom. power: 60W.
Frequency response: 91Hz-20KHz.
Mounting depth: 57.2mm
Grilles supplied.
Sold in pairs
Only need to to play mid and high.
Our Price: £129.99
Product Features
Voice Coil: 32mm.
Motor: 90mm.
Filter 6 dB/octave
Max. power: 160W.
Nom. power: 80W.
Grilles supplied.
Sold in pairs
Our Price: £94.99
Product Features
Voice Coil: 25mm.
Motor: 72mm.
Filter 6 dB/octave
Max. power: 120W.
Nom. power: 60W.
Grilles supplied.
Sold in pairs
MING BLUE AUDI S4
Car is on Lock down
Car is on Lock down
Bose systems have some funky settings to the headunit (Which can be disabled with VAG-Com) but if the speakers are running off the Bose Amp (The rears do, not sure about the fronts...) the speakers & amp are @ 8 Ohm... if you stick 4 Ohm speakers in tehre with BOSE headunit settings its going to cause something to break somewhere.
just out of interest has anyone tried adapting the wiring for the bose amp for an aftermarket jobby?Im assuming that 2 of the wires going to the bose amp are RCAs from the headunit? I was thinking of a way to keep the standard headunit but possibly upgrade the amp and speakers in the car using all the existing wiring (apart from power and earth cables for the new amp if you see what i mean).
my cars for sale
