To VAG-Com users, FATS times database for the Euro S4s
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
JonnyX
Re: RE: MRC
Post by JonnyX » Fri May 05, 2006 12:51 pm
Nige_S4 wrote:
I think so, and MRC have had a fiddle, but there is definately more to come, as I'm running a mere 1.29bar peak and still have all my cats and dogs
Oops, that should've been 1.39bar peak :oops:
Are you sure it wasn't 1.4? :wink:
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
MarkB
RE: Re: RE: MRC
Post by MarkB » Fri May 05, 2006 4:56 pm
Did another run in my S4 and got...
30.1 2640 104.33 100 12 29.61 2520 68.4 1780 1080
30.9 3000 172.67 100 6 30.5 2800 157.9 2290 1720
31.72 3440 187.75 100 5.3 31.3 3200 191.7 2260 2060
32.71 3960 223.17 100 4.5 32.21 3680 191.7 2210 2160
33.53 4320 232.5 100 3.8 33.13 4160 188 2160 2200
34.49 4760 247.31 100 5.3 33.96 4520 184.2 2110 2120
35.37 5080 253.97 100 5.3 34.92 4920 175.2 2050 2040
36.28 5440 259.25 100 7.5 35.81 5280 167.7 2020 2000
37.21 5760 264.33 100 9 36.74 5600 162.4 1970 1940
38.18 6080 268.72 100 12 37.7 5920 154.9 1940 1940
39.17 6360 273.08 100 12.8 38.66 6240 148.9 1940 1920
40.18 6600 277.44 100 15 39.68 6480 146.6 1940 1930
41.19 6880 281.69 100 16.5 40.67 6760 142.9 1940 1930
The last 2 columes are boost requested and actual. They look ok but the maf reading still looks high to me.
FATS time was 6.5 seconds again though obviously not so acurate with the extra channels logged. Is 6.5 seconds OK for AMD mapped with a Miltek Cat back exhaust?
Mark
Nige_RS4
RE: Re: RE: MRC
Post by Nige_RS4 » Fri May 05, 2006 5:30 pm
Mark, 6.5 is about right for a std S4 - you should be in the region of 5.5 or less! I take it the 3rd column is the MAF reading - it does look a bit high - I've never seen one read high before, speak to Minhea at MRC and get his opinion.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
S2tuner
Trader (Expired)
RE: Re: RE: MRC
Post by S2tuner » Fri May 05, 2006 6:44 pm
Mark, your high MAF numbers come from excessive boost levels for K03 turbos, look at your timing and compare it with other cars that have posted logs, you're running 5.3 degrees advance at 4700 and 5000 RPM, this is way too low.
Basically you're running very high boost which flows lots of air, but the air is so hot and the backpressure before your turbines is so high that the engine chokes and can't produce power because it can't run decent timing advance.
HTH,
Mihnea
MarkB
RE: Re: RE: MRC
Post by MarkB » Fri May 05, 2006 7:20 pm
Thanks Mihnea, I think that does help. So hopefully I have no boost leaks but the map is crap.
I wonder how long things will last like this... are AMD maps normally like this?
Mark
saf
RE: Re: RE: MRC
Post by saf » Sat May 06, 2006 12:03 am
They shouldnt be like this on an AMD chip. Although AMD run higher boost on their remaps than most other companies from what ive read on this site.
Did you just get your AMD map mate?
MarkB
RE: Re: RE: MRC
Post by MarkB » Sat May 06, 2006 8:50 am
Car came mapped when I bought it. I'm thinking I'll do some other mods and get a remap...
Mark
saf
RE: Re: RE: MRC
Post by saf » Sat May 06, 2006 3:34 pm
Im going to get a Custom stage2+ done next week from MRC. Im sure Ill be recomending it to you. Willl be much better than a generic AMD map me thinks.
MarkB
RE: Re: RE: MRC
Post by MarkB » Sat May 06, 2006 4:13 pm
This was a 'custom' AMD map that showed 320BHP.
Mark
CliveH
Re: RE: Re: RE: MRC
Post by CliveH » Sun May 07, 2006 2:48 pm
MarkB wrote:This was a 'custom' AMD map that showed 320BHP.
I didnt know AMD did custom remaps.
Clive
MarkB
RE: Re: RE: Re: RE: MRC
Post by MarkB » Sun May 07, 2006 7:19 pm
Maybe they don't, maybe they just doing the standard map and tell you what the car is showing...
Mark
CliveH
Post by CliveH » Fri Jun 23, 2006 11:05 pm
Right guys, I've just got round to doing this as I'd like some comparative data before the next set of mods.
I achieved 5.74 and 5.76. MRC tuned stage1, ambient temp 18.5C, 3/4 tank petrol, and just me.
Thought I'd get a bit better than that, but we'll see what the trip to MRC brings tomorrow...RS4 exhaust and gutted precats going on, and maybe another little tweak of the ECU...
Clive
Paulm
Post by Paulm » Fri Jun 23, 2006 11:12 pm
that sounds about right. I got 5.7 before my pre-cats were done. After they were done I can run more boost and advance now my best is 4.53 4.6 was the average of 2 runs
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
911 Turbo Remapped. Hated it
RS6 V10 700BHP crazy
MarkB
Post by MarkB » Sat Jun 24, 2006 8:20 am
My first FATS run was 5.94 with an AMD map and Miltek cat back. I must get out and find some flat road that I can go both ways on... Can the pre-make so much difference??
Mark
CliveH
Re: RE: Re: RE: Re: RE: MRC
Post by CliveH » Sun Jun 25, 2006 1:26 pm
CliveH wrote: I achieved 5.74 and 5.76. MRC tuned stage1, ambient temp 18.5C, 3/4 tank petrol, and just me.
Right, did a little run this morning and got 5.63 - this is after my trip to MRC yesterday for fitting of RS4 exhaust and gutted precats and another little tweak of the ECU. (ambient air 18C, just me plus half a tank of fuel)
I expected a little more than that but I'm running Tesco 97 at the moment (there's no 99 in Banbury) and the runs prior to these mods were with Tesco 99.
I'll do another run after I fill up with 99 again later in the week.
Clive
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 55 guests
