710A DVs standard fit on RS4??
2.7 V6 30v biturbo - 380 bhp
CliveH
Post by CliveH » Mon Apr 17, 2006 9:11 am
I'm being careful not to "hijack" other threads - inspected a car for a forum member yesterday, http://www.rs246.com/index.php?name=PNp ... ic&t=53265 , and discovered it had 710A DVs fitted - were the 710Ns not fitted as standard to the RS4s...?
Clive
maxxximus
RE: 710A DVs standard fit on RS4??
Post by maxxximus » Mon Apr 17, 2006 9:21 am
ASAIK 2.7 s4/rs4 fitted with the A's but N's fitted to 1.8T TT from factory.
Simple and cheap upgrade to give you peace of mind.
DavidT
Post by DavidT » Mon Apr 17, 2006 9:57 am
Yep, only the TT had them.
CliveH
Post by CliveH » Mon Apr 17, 2006 10:19 am
And the 225 S3...?
Clive
kiwi_mtm
Post by kiwi_mtm » Tue Apr 18, 2006 3:29 pm
My rs4 has 710A's, and this has always puzzled me why Audi didn't use the "N".
clived
Post by clived » Wed Apr 19, 2006 8:52 am
kiwi_mtm wrote:My rs4 has 710A's, and this has always puzzled me why Audi didn't use the "N".
When did the 'N' revision come out?
B7 S4 Cab
B5 RS4: MRC custom remap, Milltek 100cpi cats and rear system, RS6 8-pots, H&R PCS coilovers, H&R ARBs, AWE DTS, Tanoga Shortshift, Dynaudio / Focal / Genesis / iPod audio: SOLD, and still missed. One day....
Nige_RS4
Post by Nige_RS4 » Wed Apr 19, 2006 9:13 am
710A was std fit on the RS4, the 710N version (rather than revision) came out for the 225BHP 1.8T engine and although the diaphragm is not as thick as the 710A, it is actually less prone to tearing.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
ConvictS4
Post by ConvictS4 » Mon May 15, 2006 2:13 pm
Just swapped out two 710A's off 2001 B5 RS4 for two new 710N's. Neither 710A would hold vacuum from the nipple - pulled both apart for some fun and each had about 10-15m split in rubber diaphragm
2003 Daytona Grey RS6 Avant
2007 Daytona Grey B7 RS4 Cabrio on order
About as west as you can go in the colony without getting your feet wet.
LSWP
Post by LSWP » Mon May 15, 2006 4:48 pm
now thats a big split!! :D
s4woody
Post by s4woody » Mon May 15, 2006 5:32 pm
my s4 had 710c's..any idea what they are from??
GARTH ROAD MOT CENTRE LTD
020 83353032
ConvictS4
Post by ConvictS4 » Tue May 16, 2006 2:25 am
Especially in imperial measurements !
mm's of course ! :oops:
PS My 2000 S4 had 710C's before being replaced with N's
CliveH
Post by CliveH » Tue May 16, 2006 8:50 am
Never heard of 710Cs - anyone know which car these are from??
Clive
ConvictS4
Post by ConvictS4 » Tue May 16, 2006 9:10 am
It seems the 710C was used on some S4's in lieu of the 710A. To my layman eyes the A and C DV's look very similar (I now have duds of both in the store room somewhere). Audiworld has some commentary on it including the following (no responsibility accepted if all this is wrong!)
"... the TT uses a 710N valve which has a stiffer spring with a rubber diaphram. the 710C has the same spring with 3.5mm of travel up and down and a brass piston dome.
the 710N has a 7mm of travel with a rubber piston. ... "
