RS4 Brake upgrade
nooneovertakesme
RS4 Brake upgrade
Any ideas on what upgrades are suitable for RS4 brakes? Not looking at any track work but seem to get fade when pushing hard.
- SimonS4MTM
- Top Gear
RE: RS4 Brake upgrade
Welcome, fast lane hogger.
Best brake for the buck is RS6+ or B7 RS4 upgrade. No fade, even on track!!!
itaplikeabiatch
how much would that cost? the rs6 upgrade that is.
£1550 for calipers, custom brackets, discs and pads. email us for more details.
Thanks,
Mihnea
Thanks,
Mihnea
laurentrs4
May I recommend just the big calipers if you don't intend to go on a track. Had this on my RS4 Stage III with new standard discs, and it was more than adequate! Having said that the RS6 discs may not be that much more. Seems a good price from Mihnea especially as a standard RS4 discs and pads ONLY from Audi (admitedly all round) are that price without the calipers. They look great too.
RS4 B5. Where it all started.
RS6+ Never to be replaced.
Replaced by RS6. I like(d).
Back with C6 RS6
And again C7 RS6
Back with C6 RS6
And again C7 RS6
Re: RE: RS4 Brake upgrade
It's the way to go, IMHO...S2tuner wrote:Best brake for the buck is RS6+ or B7 RS4 upgrade. No fade, even on track!!!
Clive
RE: Re: RE: RS4 Brake upgrade
the other options include six pot calliper conversion and floating discs from AP Racing, but will cost you a further £500 or Movit conversion a further £1500.....
£ for £ RS6 is probably the way to go.....
- harry
I wouldn't be so quick to dispell the efficacy of the new B7 RS4 stoppers
Practise safe sex & drive a hybrid if you can...
Mihnea, they fade on the RS6 on track, so is there that much difference in the weight/momentum of an RS4 and RS6 to eliminate fade?S2tuner wrote:Best brake for the buck is RS6+ or B7 RS4 upgrade. No fade, even on track!!!
The ability too cool between load won't be any different.
Something to do with a 6 being considerably heavier than a 4 might make the difference....rs666 wrote:Mihnea, they fade on the RS6 on track, so is there that much difference in the weight/momentum of an RS4 and RS6 to eliminate fade?S2tuner wrote:Best brake for the buck is RS6+ or B7 RS4 upgrade. No fade, even on track!!!
porsche
or you could also go porsche cayenne route..6 pots and no fade as yet..
- Attachments
- porsche 025.jpg (129.68 KiB) Viewed 2052 times
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
RE: porsche
The cayenne kit is nice indeed but why use a smaller than stock RS4 disc on an RS4, i.e. 352mm vs. 360? Also, from what I've heard, there's LOTS of machining on the front hub carriers involved on an RS4 for the Cayenne kit...
Just a thought...
Mihnea
Just a thought...
Mihnea
