DEAD TURBO 2
DEAD TURBO 2
As per post on track day day forum, turbo gone, local garage say blades possibly in contact with housing causing whinning sound from 1500rpm and half throttle.
I presume there has been a bearing failure, however thare was no noise from the turbo previously and when it happened (changing from 2 to 3rd) there was an instant and total loss of boost. all hoses checked nothing obvious.
Question would the car detect a turbo failure and go limp immediatly.
there is nothing showing on vagcom apart from an out of limits reading which was there before.
RE: DEAD TURBO 2
Dear me, sorry to hear that!! Sorry cant help with the VAG-Com issue. Hope a nice set of shiny K04's make it into the engine bay and this becomes patrially worthwhile.
- SimonS4MTM
- Top Gear
RE: DEAD TURBO 2
Boost loss may happen because turbo stalled when the blades hit housing
RE: DEAD TURBO 2
Sorry to hear that....hope you get it fixed soon.
RE: DEAD TURBO 2
jimbo will have some info about the k0,s soon..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
thanks for the concern
I am still able to drive the car.....must now be the slowest S4 in the world....to prevent turbos spooling up i have to drive at 1/10th throttleand no more than 3000 rpm so 0-60 about 45 seconds
Well you've gotr to laugh or you'd cry especially with a £3500 bill around the corner
jimbo
jimbo
Sorry to hear that, been there.
If you are getting the siren sound it is likely a turbo is toast.
You probably have a boost leak as well.
There is a way to stop the car requesting boost, MRC Doug told me but I've forgotten what it is. Recommended as you may be super lucky, some boost leaks sound similar to turbo death.
The ECU cannot detect turbo failure unfortunately.
What happens when you spool up jimbo, does it whistle like a good-un ....? or does it lock up..?
My first S4 had an HKN chip from new, it was running same turbo,s as new as far as I was aware, in the winter my friends could hear me 2 roads away.......
went just as well coz i got bored of the noise and bunged some new k03's on that I had lying around,(after 2.5 years!) made no difference in performance, if anything with the pressure sensing pipe fixed(had a crak on banjo coupling) it was slower, because it didnt overspool anymore.........
I still have the old turbo's and you can see where they were both stiking the compressor housing, for along time... b@stard when they do go though
@Tartan Rob..... can you dial up the b/pressure that way .. or is it capped ..?
David
David
Precausion
Hi there, Sorry to hear about your blower. Same thing happened to me last year. As a precausion Kim @ QST told me to disconnect the cables to the N75 valve. This will stop them trying to boost above 0.5 bar or something around that. Good luck with the KO4s, the only way is up now!
Ben
Ben
Users browsing this forum: No registered users and 81 guests
