headlight washers
1.8 I4 20v turbo - 207bhp
1.8 I4 20v turbo - 222bhp
15ajh
headlight washers
Post by 15ajh » Fri Feb 10, 2006 8:26 pm
Hi there
just wandered if anyone had experienced the headlight washers not fully retrecting after use??? if so can they be reset??. Car is a second car and only does 8K a year, there for could it be lack of use?
Cheers Alan
shineydave
RE: headlight washers
Post by shineydave » Fri Feb 10, 2006 11:25 pm
there's some fairly strong springs in there to pull them back down, are they easy to pull out by hand?, could be a broken spring or just sticking
15ajh
Post by 15ajh » Sat Feb 11, 2006 1:52 pm
Near side washer seams to be about 3mm from closing down tight. happened after a couiple of days of cold weather, during which the car was not used. offside one seams to be closed but not as tightly as it use to.
checked both and they can't be pulled out by hand at all!
alan
RobTheHungryMonkey
Post by RobTheHungryMonkey » Tue Feb 28, 2006 3:00 pm
exactly the same problem!
Though haven't investigated it properly yet
david7m
Post by david7m » Fri Mar 10, 2006 10:11 pm
Me too :-(
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat Image
Return to “S3 (Typ 8L) 1999-2003”
