Wheel and Flywheel Torque
Posted: Thu Aug 03, 2006 1:54 pm
by rweir
Question, I know that with 4wd cars there is about a 23% loss of power through the drivetrain to the wheels.
Is this the same for torque, or would I be right in saying this is not affected ?
RE: Wheel and Flywheel Torque
Posted: Thu Aug 03, 2006 11:00 pm
by harperboy
Doesn't that totaly depend on what you are measuring power in, as you can measure power in torque cant you? Or by power do you mean bhp?
Re: RE: Wheel and Flywheel Torque
Posted: Thu Aug 03, 2006 11:20 pm
by rweir
harperboy wrote:Doesn't that totaly depend on what you are measuring power in, as you can measure power in torque cant you? Or by power do you mean bhp?
Well, for example, I have some figures which are is for power?! at wheels.
BHP: 376
Torque: 448
So, if I do the calcs and assume 23% "power" loss, I get lets say around 450 BHP, I assume the torque stays the same?
RE: Re: RE: Wheel and Flywheel Torque
Posted: Thu Aug 03, 2006 11:37 pm
by DavidT
Same losses for bhp and torque I think, 26% or 75 bhp losses for Torsen Quattro are good estimates.
Posted: Fri Aug 04, 2006 7:31 am
by GrahamS4
I'm no authority on this (can't even claim to fully follow it), but repeating what I have read elsewhere, a dyno does not meaure BHP it can only measure torque, the BHP being calculated from the measured torque.
I have never heard of people talking about looses and torque. Until convinced otherwise, I think torque is measured and does not differ from flywheel to wheels.
Posted: Fri Aug 04, 2006 9:46 am
by JonnyX
OK, the power loss through the drive train is pretty much an absolute figure
rather than a percentage (if we are talking about losses between the flywheel
and the road). I hate the use of percentages on modified cars (unless you
are expressing the difference between the measured crank power and the measured
wheel power as a percentage ;-) ).
Torque is a force (well, technically it's a moment a of force).
Power is the amount of work done in a specified time interval.
Again, to simplify, the power of the engine is the amount of torque it outputs
over a certain time period. This is normally expressed:
Engine RPM/5250 * torque = power. (on your dyno plots torque and power should
cross/touch at 5250 RPM)
disclaimer: I am using 5250 from memory, it may be wrong.
For arguments sake, if a standard car makes 200bhp@crank and loses 40bhp through
the transmission this represents a transmission loss of 20%. If the same car
is tuned to 400bhp and the same 20% loss figure used it now loses 80bhp through
the transmission. This is 40bhp, or ~30KW, of addtional power loss. Where did
we lose this extra power? The tranmission components are identical! (most
tranmission loss is power loss in accelerating rotating components). There will
be a slight increase in losses as you exert more load on components, more hysteresis
and therefore more heat. Not 30KW worth though.
Personally, I think wheel figures are fine ;-)
Re: RE: Re: RE: Wheel and Flywheel Torque
Posted: Fri Aug 04, 2006 10:57 am
by GrahamS4
JonnyX wrote:Engine RPM/5250 * torque = power. (on your dyno plots torque and power should
Mine cross at 5200rpm bang on.
Torque
Posted: Wed Aug 09, 2006 10:23 am
by viperbl
So,
After looking at BRETTCOLLINS post here I see he has two dyno runs, wheel and flywheel.
From what I can see, the torque and HP go when the flywheel dyno run is done. So, would this mean my flywheel torque should go up? Mine
Re: Torque
Posted: Wed Aug 09, 2006 4:22 pm
by JonnyX
viperbl wrote:So,
Unless the flywheel figure was measured on a bench dyno it's
a calculated figure. You can calculate how much energy is
stored in the rotation of the driveline components by doing
a coast down run and knowing what the load resistance is of
the RR's rollers. You can then use this to calculate power at
the flywheel.
