Page 1 of 2
VW Gti Edition 30 advice
Posted: Sun Jul 16, 2017 8:27 am
by Stevie1982
So due to a change in work situation I had to let the b7 rs4 and have replaced it with a mk5 golf gti edition 30. Only had a it a few days and am quite impressed with it so far, now I'm registered on one of the sites however I've always found this site to be helpful so thought I'd ask for some opinions regarding a stage 1 map. I was looking at the obvious of MRC and appreciate they're big on audi but wasn't to sure as for vw, then there's VAGtech who use the Revo software and finally R-tech who I've personally never heard of them but a Google search brings them up with results on vw forums. All 3 offer a similar price with similar end results however who would you use
Best Regards Steve
Re: VW Gti Edition 30 advice
Posted: Sun Jul 16, 2017 8:55 am
by Nige_RS4
The Ed 30 engine is virtually the same as the Audi 8P S3 engine, so if you are happy with using MRC then go with them, expect 310ps with a stage 1 remap. If you're manual watch your clutch though as they are prone to slipping.
Posted: Sun Jul 16, 2017 9:17 am
by Stevie1982
Hi Nige, thanks for the reply. I'm on a dsg box as I've always wanted to try it will that be an issue do you know?
Posted: Sun Jul 16, 2017 9:38 am
by Nige_RS4
No, the dsg box is good for up to stage 2 on that engine. Had my S3 mapped by MRC, so you will be in good hands. Just make sure you've checked / replaced the usual suspects before mapping; plugs, dv, pcv, fuel filter.
Posted: Sun Jul 16, 2017 9:48 am
by Stevie1982
Usual suspects? Car is going in for a major service and cambelt with vw this week coming not sure if they replace the fuel filter so I'll ask.
Regarding the dv, pcv.... Why does the dv need to be replaced? Only reason I ask is mrc haven't mentioned it
And PCV? What is this
Posted: Sun Jul 16, 2017 9:53 am
by Nige_RS4
DV is renown for splitting, even on std boost - newer / stronger part available. PCV is the breather valve on the front of the engine and also splits / leaks - has been superseded by a newer part. Dealers won't replace the fuel filter - they claim it is good for the life of the engine! Also, plugs should be changed every 10-15k miles (VW will tell you 40k miles)
Posted: Sun Jul 16, 2017 1:22 pm
by Stevie1982
Well it's in for its 80k service so I should hope the plugs will be changed yet to be on the safe side I'll ask the question along with request the fuel filter to be changed.
DV assume that would be something like a forge item, do they do a Recirculating valve over a vta as I'm not looking for the additional noise.
Posted: Sun Jul 16, 2017 1:59 pm
by Nige_RS4
No, stick with OEM for the DV. You can check it yourself, see what version you have. If you have anything that doesn't end in a G then probably best just to replace it for peace of mind.
80k also means DSG fluid and filter and Haldex fluid and filter?
That could be an expensive service if you're getting it done at a main dealer - are there no specialists near you? Could save you minimum £300!
Posted: Sun Jul 16, 2017 2:52 pm
by chunky79
Probably easier to just take the care to MRC to do everything.
Posted: Sun Jul 16, 2017 5:24 pm
by FaisalJ
I've got a mk5 GTi at home.
1. Take it to a specialist, not a main dealer.
2. Make sure the cam follower is changed if it hasn't been already
3. 80k = DSG service too
4. R-tech are meant to be the Daddy's when it comes to tuning these. I'd choose them over MRC. Too far from me, so I'm thinking about APR for a stage 2 map
Posted: Sun Jul 16, 2017 5:30 pm
by FaisalJ
5. You'll be wanting a brake upgrade as soon as you've mapped it - warning you now!
Posted: Sun Jul 16, 2017 5:54 pm
by Mav8
chunky79 wrote: ↑Sun Jul 16, 2017 2:52 pm
Good advice,that's what i'd do.
Mav8
Posted: Sun Jul 16, 2017 5:55 pm
by Mav8
Oppps double post :
Posted: Sun Jul 16, 2017 10:12 pm
by Stevie1982
Thanks Nige I'll take a look at the valve tomorrow and reorder where and if need be. I'd hope that they will do what should be done however I'll be asking about the points you've raised. You'll be surprised I've had a couple of prices back from indys Re the cambelt and vw are actually cheaper as they have an "offer" on at the moment. So as it stands it's more cost effective to let vw who are 8miles away carry it out. The car is also a one owner car with full main dealer history so it keeps that up.
@chunky you'd of thought so yet while in talks about mapping I've asked and didn't get a response to it and as above vw have been quite competitive in price and keeps the car as full main dealer.
Faisal, thanks for the honest reply. I haven't spoke with r-tech as my go to was mrc so I'll take a look
Posted: Mon Jul 17, 2017 1:10 am
by FaisalJ
No probs
Some more info on the cam follower below. Ignore at your peril! Not sure if VW would check it for you or not
https://shopdap.com/vw-audi-2-0t-fsi-ca ... -problems/
