RS6 C5 GEARBOX ,GEARS JUMPING ABIT??
ANY HELP PLEASE ON SOMETIMES PULLING AWAY THE CAR REVS THEN JUMPS INTO GEAR BUT HEN OK THROUGH THE REST OF GEARS ANYBODY HAD SIMILAR PROBLEMS AND WHAT COULD IT BE ,,, NEED NEW GEAR OIL OR BOX ?? CHEERS
Re: RS6 C5 GEARBOX ,GEARS JUMPING ABIT??
You have other issues that need sorting first.
issues like what ??
Was caps lock but you've sorted that out.
I would suggest getting the gearbox serviced, do you know when it was last done?
Are you North or South? Could take it to Unit20 if North or MRC if South.
CRANK SHIFT SENSOR NEEDS REPLACING , SO HOPEFULLY ITS UNDER WARRANTY .
Is your computer/phone under warranty? Your caps lock keeps getting stuck
Crank sensor giving you that fault is it??
CAN'T WRITE MAN SO ALWAYS WRITE LIKE THIS SOZ WOR KID , I CRANK SENSOR
Ummm, okay! O.obrassy1975 wrote:CAN'T WRITE MAN SO ALWAYS WRITE LIKE THIS SOZ WOR KID , I CRANK SENSOR
How do you expect us to help if we can't even make sense of what you're saying??
Box is probably fooked, same issues I was having when mine went.
