HELP WET REAR PASSENGER FLOOR ON ME RS6
brassy1975
Post by brassy1975 » Sat Nov 22, 2014 3:20 pm
HI JUST CHECKING ME NEW CAR OUT WHEN IV DISCOVERED THE REAR PASSENGER FLOOR REALLY SOAKING LIKE SOME ONE HAS POURED WATER ON IT , CHECKED ALL THE SEALS AND THEY LOOK FINE COULD IT BE OOT ELSE LIKE AIR CON OR SOMETHING ??????
Re: HELP WET REAR PASSENGER FLOOR ON ME RS6
Post by bam_bam » Mon Nov 24, 2014 12:11 am
Stop shouting! Turn off your cap-lock.
Your drain is probably blocked under the scuttle or you've parked on a hill. The water comes in at the pollen filter and takes the lowest path to the rear near-side.
Pull out the scuttle and clean out your drains.
brassy1975
Post by brassy1975 » Mon Nov 24, 2014 11:46 pm
checked under the front carpet and thats soaking to , is the best think to take all the carpet out and dry it properly because it'll not dry properly if i dont will it , sorry am a clueless git when it come s to cars
Post by bam_bam » Tue Nov 25, 2014 2:04 pm
Dry 'em however you can. I used a heatgun on low, it took an age.
brassy1975
Post by brassy1975 » Tue Nov 25, 2014 11:57 pm
TAKEN IT TO ME MATES PAL WHO DEALS WITH AUDIS , HE S GOING TO TAKE THE SEAT OUT AND THE CARPETS AND HANG THE CARPETS OFF AND GET THEN BONE DRY THEN FIT THEN ALL BACK IN AND FIT A NEW POLLEN FILTER , LUCKY ME ECU UNIT IS OK SO KIDS CHARGING ME £220 ALL IN SO NOT BAD I SAY .
SuprSi
Post by SuprSi » Wed Nov 26, 2014 1:15 am
Screw that, vax up as much as you can then just put a dehumidifier in the boot and a fan up front to circulate the air. Leave there for 24hrs or so and job done! You can probably hire the gear if you don't have it.
I had to do this after sitting on my key and winding all the windows down one night when it was pissing it down!
Do whichever you want but that sounds like a lot of effort.
brassy1975
Post by brassy1975 » Wed Nov 26, 2014 9:33 am
ITS TRYING TO GET ALL THE SPONGE UNDER THE CARPET DRY PROPERLY COS IF YA DONT IT WOULD START TO SMELL AND GO MOLDY , LEAST I KNOW IT'LL GET DONE PROPERLY INSTEAD OF ME TRYING TO DO IT , AND WANTS £220 NOTES I SPEND THAT IN THE BOOKIES IN 10 MINS , HA
brassy1975
Post by brassy1975 » Tue Dec 02, 2014 10:44 pm
well car all back to normal nice and dry , now just need a nice day to wash it and wax it ,,
Return to “General Car Chat”
