Standard air suspension issues
Posted: Wed Jul 22, 2020 6:15 pm
by Asian Panda
Guys,
Has any with air suspension noticed if one side of their car is lower than the other?
I took a measurement today and noticed that the driver side is approximately 5mm higher than the passenger side. Can't remember what it was that drew my attention to it.
Re: Standard air suspension issues
Posted: Mon Jul 27, 2020 7:13 pm
by Jamie_P
Yep. On my dads 2015 FL it’s exactly the same, however I measured it with fingers rather than a ruler
Posted: Tue Jul 28, 2020 11:33 am
by Saudirick
Depends where it is parked. On my drive which is level the car is level, on my parents drive which is on a slight angle the car is not level
Posted: Tue Jul 28, 2020 7:31 pm
by Asian Panda
Saudirick wrote: ↑Tue Jul 28, 2020 11:33 am
Unfortunately even on a level one side is still slightly higher than the other.
Since I now know it's there and I can't seem to get a logical reason as to why... It's p@#£ing me off!!!
Posted: Tue Jul 28, 2020 8:41 pm
by morski
the ride height can be adjusted with air suspension equipped cars using
VCDS. Have a read through the instruction on this ..
https://www.audizine.com/forum/showthre ... -with-VCDS
and you could adjust/correct the height to where you want it.
Just make a note of every change/step you adjust so you can revert it back in case its not right for you.
Posted: Wed Jul 29, 2020 7:25 am
by Asian Panda
morski wrote: ↑Tue Jul 28, 2020 8:41 pm
I've passed the link onto the tuner to see what he thinks as I'm currently using the milltek air suspension module.
But huge thanks for that info
