Oil usage
Posted: Fri Aug 09, 2019 7:49 am
by Tadass910
Does you car use oil? Drove 8000km since last oil change and When I check oil level it’s is always at max, is it normal? Maybe oil level cap broken? Before my car always used oil and oil level dropped time from time I even needed to add half litre once. Can it be because I drove short trips in a city and now drive mostly long runs that’s why oil is not burning so much.
Re: Oil usage
Posted: Fri Aug 09, 2019 3:51 pm
by dasquade
Car consumes oil depending on driving style, especially if you push it when still cold it will consume more. Be glad :).
For the record, actually the oil level should be one bar below max when cold and will raise to max once hot, but as long as you don't get a warning of too much oil, it should be okey.
*had the mmi oil reader, only works half of the time :( long life the good old oil dip stick (get one to be sure at any time).
Re: Oil usage
Posted: Fri Aug 09, 2019 6:40 pm
by Tadass910
Thanks for information :thumbs:
Re: Oil usage
Posted: Mon Aug 12, 2019 9:54 pm
by onurserkan
I’ve just drove from UK to Turkey and currently done 6000km and done an oil change before I left. My oil level was 1 bar below max and now its sitting on half way. I have been doing alot of high speed driving 150-190mph time to time and I think oil consumption is quite normal. However before i came here my day to day driving was town mainly and it did not consume any oil at all.
