Extended warranty question
Posted: Tue Feb 26, 2019 11:40 am
by guyneutron
Hi all,
Had a service done at an Audi specialist a couple of months back(11000 miles)
Around August my warranty will expire and I am looking to extend it. Will the fact that I did not go to a dealer effect the possibility of extending my warranty?
Re: Extended warranty question
Posted: Tue Feb 26, 2019 2:00 pm
by jwlanky
Plug your details in a see if it gives you a quote...
https://www.insurewithaudi.co.uk/extended-warranty
Posted: Tue Feb 26, 2019 3:39 pm
by Golfather
As long as they used genuine parts its fine. However after the warranty starts, then u need to use a stealer
Posted: Wed Feb 27, 2019 6:38 pm
by DaytonaMatt
Are you sure? I read the terms yesterday and seemed pretty clear it's parts need to be audi approved, but no mention of it having to be performed by Audi?
- Servicing must be carried out in accordance with vehicle manufacturer recommendations. Genuine Audi components, oils and other fluids or components, oils and other fluids of equivalent specification and matching quality must be used. Failure to comply with this condition will result in a warranty claim being rejected.
- Failure to keep your vehicle serviced in accordance with the manufacturer’s service schedule will void the warranty. You must keep all servicing receipts and invoices. We will be entitled to check that your vehicle has been serviced regularly and may ask to see these in the unlikely event that the condition of your vehicle does not appear to correspond with your vehicle service schedule
- Modification to the vehicle – If you would like your vehicle to be modified in any way, you should obtain our prior approval and the work should be carried out by an Audi Approved Centre. In the event that a modification, which was not approved by us, contributes to a fault, we reserve the right to reject any claim you may wish to make in relation to that fault.
Posted: Thu Feb 28, 2019 9:12 pm
by Anth
I can't remaber who Audi use now to extend I had it n my last C7 none FL and sure it was Lawshield UK If so as DMatt said you can use any approved garage for works no issue .
