Page 1 of 4
2014 RS6 C7 Cutting out on start up.
Posted: Sat Feb 16, 2019 2:00 pm
by dannyuk
Hi,
Not sure if anyone else has had this issue or any input! I have a 2014 C7, I would say 1 out of 30 starts it fails. It will fully crank, sort of sounds like it is firing up then just cuts out. Once it fails to srart once it will then not start by itself unless I put down some throttle, at which point it will start instantly!
Seems very weird to me, as I am pretty sure it is an electronic throttle so not sure why me putting my foot down helps.
I am probs have to take into the stealers, just was not sure if anyone has any quick fixes I could try first?
Danny
Re: 2014 RS6 C7 Cutting out on start up.
Posted: Sat Feb 16, 2019 2:41 pm
by marc_cope
I’m having the exact same problem with my 2014 C7 RS6. Been in to dealers they can’t find anything wrong surprisingly. Keep us updated when you have some news.
Marc
Posted: Sat Feb 16, 2019 2:45 pm
by rtd
marc_cope wrote:I’m having the exact same problem with my 2014 C7 RS6. Been in to dealers they can’t find anything wrong surprisingly. Keep us updated when you have some news.
Marc
I had a slightly different issue and after two failed attempts to diagnose a fault I rang Audi CS, low and behold they booked car back in changed some bits and it’s been fine ever since. Get onto Audi CS.
Posted: Sat Feb 16, 2019 3:01 pm
by Markwes
I have the same issue, also a 2014 car, cuts out on start up and have to give some throttle input to get it to fire up again. I’ve noticed when it cuts out the auto stop/start icon is on the dash which seems strange.
When it happened the other day I got a fault with the auto stop/start system which cleared itself after a few days.
Posted: Sat Feb 16, 2019 3:24 pm
by rtd
Markwes wrote:I have the same issue, also a 2014 car, cuts out on start up and have to give some throttle input to get it to fire up again. I’ve noticed when it cuts out the auto stop/start icon is on the dash which seems strange.
My issue was start/stop related and they replaced the fuel pumps alongside some other bits can’t remember what.
Posted: Sun Feb 17, 2019 6:24 pm
by dannyuk
Markwes wrote: ↑Sat Feb 16, 2019 3:01 pm
Yes, mine also says its Start Stop straight after it fails.
Posted: Sun Feb 17, 2019 6:25 pm
by dannyuk
rtd wrote: ↑Sat Feb 16, 2019 3:24 pm
Was this done out of warranty? Would be good to get an idea on cost!
Posted: Fri Mar 01, 2019 1:59 pm
by RS4Guy...
Hi, I have an RS4 B8.5 (2015), and the engine was periodically cutting out whilst driving.
My AR (Authorised Repairer) said that it was due to an intermittent fault on the fuel pressure sensor. The part itself was about £60 but required 4.5 hours of labour to fit, as the whole top of the engine has to be removed. The quoted cost including labour and VAT was the best part of a four-figure sum...
Posted: Sat Mar 02, 2019 11:25 am
by Iain
My 2017 PE there up a start stop fault the other week, wouldn't start, then did start. Not seen the issue since
Posted: Wed Mar 20, 2019 7:51 pm
by Tadass910
dannya32 wrote: ↑Sat Feb 16, 2019 2:00 pm
Hi,
Danny
What mileage has your car?
Posted: Wed Mar 20, 2019 7:55 pm
by dannyuk
Hey,
Its on 40,000
Danny
Posted: Tue Apr 16, 2019 7:54 pm
by dannyuk
Hi,
Have an update on this, went into Audi last week, they came back with the below:
Exhaust - Aftermarket exhaust system fitted,
pressure control valve's removed, faults stored for
both valves, this could potentially cause the starting
when warm issues, would require fault to be
rectified before further investigation can be carried
Has anyone else on here had the PCV's removed? Is that normal practice with an aftermarket exhaust?
Cheers,
Danny
Posted: Tue Apr 16, 2019 9:46 pm
by MikeFish
If they are talking about the exhaust valves then I'd be amazed if they caused any starting problems and it's just the useless techs trying to pick a problem with the only issue they can see.
Posted: Tue Apr 16, 2019 9:54 pm
by dannyuk
I was thinking that - on your Miltec do you get any codes thrown up on the diagnostics?
Posted: Wed Apr 17, 2019 7:55 am
by MikeFish
When I disconnected my exhaust valves on the standard exhaust it used to throw up fault codes until I fitted some milltek valve delete modules that basically trick the ECU into thinking the valves ares till connected. When the milltek exhaust was fitted 3 years later I kept the valves disconnected and the delete modules fitted.
