Page 1 of 2
After Market discs
Posted: Fri Mar 30, 2018 5:22 pm
by SausageMike
Hi Fellas
What after market discs should i go for as i'm about to replace front and rear any time now.
And don't want the wavey factory crap as they don't last 5 minutes :boohoo:
Re: After Market discs
Posted: Fri Mar 30, 2018 5:49 pm
by MikeFish
What was wrong with the standard discs? Mine have done 24k and still going.
some people have reported aftermarket discs didn't perform any better so best choice is to use better pads and fluid or retrofit ceramics.
Posted: Fri Mar 30, 2018 5:50 pm
by rtd
I had 30k out of my fronts.
Posted: Sat Mar 31, 2018 2:39 am
by becausephilchow
Should be plenty of AP Racing Discs that different manufacturers use.
Posted: Sat Mar 31, 2018 5:25 am
by Markp
I would stay standard. 30 k out of my fronts and rears still got another 10-20k in them.
Posted: Sat Mar 31, 2018 7:55 am
by SausageMike
Just that I'm coming up to 27k miles and have developed some brake judder. And heard there's a lot of problems with warping on the standard discs.
Mostly the judder is braking from 60 when more on the cold side.
Posted: Sat Mar 31, 2018 8:12 am
by Markp
That is because your discs are on the way out at 27k. Not unusual for front discs to be shot and original pads to still have life. Measure the disc thickness.
Makes your comment re not lasting 5 minutes look a bit daft ;)
Posted: Sat Mar 31, 2018 8:59 am
by SausageMike
5 mins seem the norm on other threads i thought i had a good set to those people. just needing new ones and asked what other options are out there. :bigblink:
Posted: Sat Mar 31, 2018 9:46 am
by Markp
Just be careful if you go after market. You might end up being worse off. Perhaps better the devil you know....
Also hunt around for prices. Some parts depts will give big discounts. Audi Stoke and Crewe often v competitive on eBay. I bought a full set of discs, pads and sensors for £1195 from Stoke (albeit a couple of years ago).
Posted: Sat Mar 31, 2018 5:55 pm
by SausageMike
wow thats a good deal :D
Posted: Tue May 01, 2018 2:14 pm
by tartan_rob
Who makes the standard discs? Get the PN for them and go direct.
Posted: Wed May 16, 2018 11:17 pm
by shanek
The OEM discs arnt vented correctly, VAG in their quest to save money use the same casting for the internal venting of the drivers and passengers front discs meaning only the passengers disc clears the hot air effectively. The drivers side disc (with prolonged hard use) overheats and warps creating the dreaded disc judder felt by a number RS owners on this forum (including myself).
I replaced the OEM front discs with Vagbremtechnic 2 piece discs (an AP Racing disc mated to Vagbremtechnics bell). Now, both driver and passenger discs have the correct internal venting pattern to allow the discs to be cooled correctly during use with almost no chance of disc warping.
Vagbremtechnic are currently running a 10% discount event until the end of May should anyone be interested.
Combined the new discs with Ferodo DS2500 Pads to great effect, just waiting to get new brake fluid, braided lines and rear pads installed to get the full benefit.
Posted: Thu May 17, 2018 6:10 am
by MikeFish
Yes the unhanded front discs were the same on the B7 and probably many other RS models too but I've never managed to warp any of those either. They are big thick discs, must take an awful lot of heat to warp them.
Posted: Thu May 17, 2018 8:40 am
by Markp
OE discs are vented correctly. It doesn't matter which way you mount them - they vent effectively if rotating forwards or backwards. And my dealer said it was near side discs that give trouble - something they blame on road debris and going through puddles etc (rightly or wrongly). And they are the discs supposedly put on the right way?? I think it's a red herring.
Edited to add: we had this debate when racing with after market discs on 968 in Porsche Championship. A straw poll around the pits with a temp gun revealed same spread of brake temps regardless of whether discs were handed or not (n/s were hotter but it was Castle Combe - clockwise circuit).
Posted: Tue May 22, 2018 1:57 pm
by EireRS6
Hi guys,
Sorry to butt in, but have any of you used autodoc before? Have found the following and just wondered if anyone has bought from them before.
https://www.autodoc.co.uk/zimmermann/1738376
heers
