Page 1 of 2
New battery
Posted: Tue Jan 09, 2018 3:21 pm
by rtd
Think I need to replace my battery has anyone replaced a battery thus far? Where is best place to get one, should I stick to the original supplied unit or get a better one?
Re: New battery
Posted: Tue Jan 09, 2018 3:31 pm
by don0301
Have you tried re-conditioning it?
Re: New battery
Posted: Tue Jan 09, 2018 3:33 pm
by rtd
No mate but I think I need to be reconditioned £528 from Audi!!!!
Re: New battery
Posted: Tue Jan 09, 2018 6:38 pm
by rtd
Would the battery be covered by the manufacturers warranty which is still valid until end of October.
Re: New battery
Posted: Tue Jan 09, 2018 7:08 pm
by doodlebug
No!
Re: New battery
Posted: Thu Jan 11, 2018 9:02 am
by don0301
Can get a CTEK 5.0 for £50-60?
Cracking bit of kit, can bring a battery back from seeming dead.
Recommended to "condition" your battery once a year, or use to charge if car left for a while.
My previous car was 12 years old still on original battery.
Re: New battery
Posted: Thu Jan 11, 2018 10:37 am
by feeltheburn
rtd wrote: ↑Tue Jan 09, 2018 3:33 pm
Crazy prices! I understand that the humble battery of yesteryear is now a sophisticated bit of kit so much so that the car systems need to be updated with the identification number of the battery to optimise its charging and life! So not sure if just any garage can fit a replacement (without
VCDS or the like). I’d hope that if it is a like for like replacement (capacity/ chemistry etc) then the coding would only be a housekeeping and not a technical issue.
http://wiki.ross-tech.com/wiki/index.ph ... eplacement
If you do get your existing one load tested remember not to allow then to apply the tester for more than a 1 or 2 seconds or you will definately need a new one (the internal battery temperature will rise so quickly it will damage the internal plates etc!)
Re: New battery
Posted: Thu Jan 11, 2018 3:30 pm
by rtd
Thanks for the advice folks will look into CTEK, but I think in my current circumstance I may just replace.
Re: New battery
Posted: Thu Jan 11, 2018 4:07 pm
by harrier
I can certainly recommend the CTEK as I have rejuvenated quite a number of car batteries with mine.
As regards a replacement battery, do look at carbattery2u.co.uk They do great deals, including the cost of rapid delivery.
eg. their 019ss (stop start)battery:
Varta Car Battery AGM 019 / G14 / DIN 595901085
£190.33 ( inc. Vat)
Re: New battery
Posted: Thu Jan 11, 2018 10:41 pm
by LukasPukas
Doesn't a new battery need to be coded for some reason?
Re: New battery
Posted: Fri Jan 12, 2018 9:31 am
by rtd
slight issue its totally dead now. went to start it this morning after two days and nothing - am I right in assuming battery is in boot? Car is parked up against rear wall does it have any terminals in engine bay where I could jump start it?
Re: New battery
Posted: Fri Jan 12, 2018 9:36 am
by Eddie555
Yes Gurj. Battery in boot underneath everything. There’s battery jump access under bonnet.
Re: New battery
by rtd
Mate you are a
Re: New battery
Posted: Fri Jan 12, 2018 12:30 pm
by morski
Call out Audi breakdown assist! They may even change it there and then under warranty as dealers vary between what they will not replace under warranty
Re: New battery
Posted: Fri Jan 12, 2018 12:33 pm
by rtd
I’m not sure I have that mate or is that a free service with the warranty?
