Page 1 of 2
Thermostat open circuit p0597
Posted: Tue Jan 02, 2018 5:05 pm
by l19ydm
Hi All,
I have been having some issues with stop/start system not functioning and emissions light coming on. Had it diagnosed as above however the quote to replace the thermostat is for 6-7 hours work plus parts.
Has anyone undertaken this task or seen a how to writeup?
Many thanks
Sent from my EVA-L09 using Tapatalk
Re: Thermostat open circuit p0597
Posted: Tue Jan 02, 2018 7:48 pm
by rtd
This is interesting reading what issues are you having with the start/stop?
Posted: Tue Jan 02, 2018 8:45 pm
by l19ydm
rtd wrote:This is interesting reading what issues are you having with the start/stop?
Message on dash that start stop function not available. I believe the emissions light comes on due to mixture, every time the light is on there are circa 100 of the above faults and 1 mixture fault on lambda probe.
Thermostat are normally a very simple Swap but without engine diagrams etc I am reluctant to tackle it.
Posted: Wed Apr 08, 2020 9:15 am
by Parkerdan
l19ydm wrote: ↑Tue Jan 02, 2018 8:45 pm
Hi, did you have any luck with this after? I have same issue.
Posted: Sat May 30, 2020 2:37 pm
by gazzars4
I’ve got the same fault come on this week
Posted: Sat May 30, 2020 2:40 pm
by gazzars4
That’s the codes stored with the EML on.
Posted: Sat May 30, 2020 7:08 pm
by Tadass910
gazzars4 wrote: ↑Sat May 30, 2020 2:37 pm
I bet you car is facelift and you have 40.000 miles and such problems occur on your car, interesting, maybe you car is tuned?
Posted: Sat May 30, 2020 7:30 pm
by gazzars4
Yes face lift and MRC tuned needing sorting might drop MRC a email see if they can sort the issue.
Posted: Sun May 31, 2020 2:56 pm
by Tadass910
gazzars4 wrote: ↑Sat May 30, 2020 7:30 pm
Could be tune related who knows
Posted: Tue Jun 02, 2020 1:39 pm
by Royclarke
Mines stock and 42000 miles and had the start/stop fault and logged a coolant fault,they gone now now that I drive it everyday,I read somewhere with everything on these cars the batterie can start to drain and throw some faults,also when it goes into 4 cylinder mode the alternator can shut it’s self off because it uses more fuel to run it all the time
Posted: Tue Jun 02, 2020 3:19 pm
by Tadass910
Royclarke wrote: ↑Tue Jun 02, 2020 1:39 pm
So what causing a problem then?
Posted: Tue Jun 02, 2020 4:16 pm
by Royclarke
Well for my car I’m guessing it was the batterie was draining and throwing so codes,I also read of this same thing happening on someone else’s car to
Posted: Tue Jun 02, 2020 7:56 pm
by Tadass910
Royclarke wrote: ↑Tue Jun 02, 2020 4:16 pm
If i understand correct when batteries coming to an end you should receive a yellow light like this:
Posted: Thu Jun 04, 2020 8:08 am
by gazzars4
Mine is the original battery still,looking back on invoices a new battery was quoted last year but wasn’t fitted. I’m going to get mine tested see if that is the cause interesting.
Posted: Thu Jun 04, 2020 4:09 pm
by Tadass910
Mine original battery 2014 year still kicking
