Page 1 of 2
Fitting Lowering springs - DRC question
Posted: Sat Jul 08, 2017 7:28 pm
by Webber498
Hi all,
I'm new to the forum and have recently bought a 2016 RS6 with the dynamic pack.
I've bought some H&R 20mm lowering springs and my friend who owns a VAG specialist garage is going to fit them for me but he pointed out that ERWIN advises that the DRC system needs draining and refilling after the springs are fitted, he tells me this is because a hydraulic link between the shocks needs to be removed to get the shock out.
Is that what other people who had springs fitted have experienced? I read some other posts saying that the DRC didn't need touching or resetting.
Adam
Re: Fitting Lowering springs - DRC question
Posted: Sat Jul 08, 2017 8:31 pm
by MikeFish
No need to remove shocks or drain them.
However some people say that the system should have it's pressure reduced slightly when lowered. I haven't lowered mine and I know plenty of other people who have done the same.
Posted: Sat Jul 08, 2017 9:21 pm
by Webber498
Thanks for the reply Mike
So the shocks don't actually need removing to fit the new springs, are they not a macpherson strut type shocks with the spring over the shock?
Just I thought they normally had to drop the shock off the car to remove the springs on that type of strut.
Adam
Posted: Mon Jul 10, 2017 8:30 am
by Webber498
Does anybody who had springs fitted without touching the DRC happen to know how it was done?
I spoke to my friend and told him that the shock doesn't need to be removed nor drain the DRC but he thinks the only way to achieve that is to use spring compressors with the shocks on the car, and he says that is archaic and dangerous... no idea if that's how others did it or if there is another way.
Any advice appreciated.
Thank you
Adam
Posted: Mon Jul 10, 2017 8:43 am
by J66kco
I phoned many Audi specialists when looking to lower. All but 2 said DRC recharge is required. Unit 20 said they could do it but never did as there's a chance something could go wrong. The other being plush automotive who never affect DRC. I have no idea how they do it (Mike may as I think that's where his was done) but I can't imagine plush just telling you how, but maybe give them a call
Posted: Mon Jul 10, 2017 9:41 am
by Webber498
Thanks, yes my friend is saying the same, it's risky doing it without disconnecting the DRC and taking the shocks off.
He is looking into buying the tools to recharge the DRC now... maybe that's the route we will have to go down
Posted: Mon Jul 10, 2017 9:55 am
by MikeFish
I don't know the details but I know lots of people who have done it without needing a recharge. Yes Luke did mine for me.
Posted: Mon Jul 10, 2017 11:42 am
by Golfather
Ive got a guide on how to do this without opening the DRC circuit, if anyone needs them pm me and I can send you the PDF.
Posted: Mon Jul 10, 2017 12:09 pm
by Webber498
Thanks for the replies.
Golfather - I've pm'd you and would really appreciate it if you could send that PDF. Cheers!
Posted: Wed Jul 12, 2017 7:06 am
by nuwanda
Hi Godfather, please can you also PM the PDF too? Thanks in advance. Phil
Posted: Thu Jul 13, 2017 5:26 pm
by Webber498
To help complete this thread, here is a link to the PDF, it's a KW fitting guide for the C7 RS6 but the process should be pretty much the same for H&R non adjustable springs.
http://docs.kwsuspension.de/ea-KWHFS-h2531000K.pdf
Mine is being done next week following his procedure so I will report back afterwards
Posted: Tue Jul 18, 2017 9:11 pm
by Webber498
I was wondering what the approximate going rate for spring fitting on one of these is? Anybody willing to share what it cost them?
Saw another thread and somebody had been quoted £450 by a place in Essex and £500 by MRC. Yet one person was saying that was way to much. Is that the right ballpark amount?
Posted: Fri Aug 11, 2017 3:40 pm
by J66kco
Got mine fit at unit 20 today. They didn't touch the DRC and cost £180+ vat. 2x technicians 1.5hrs to finish job
Posted: Fri Aug 11, 2017 7:57 pm
by MikeFish
Yeah £200 - 250 is about right for the labour. Plus factor in a decent alignment afterwards, it makes an amazing difference!!!
Posted: Fri Aug 25, 2017 7:21 am
by Gledsy
No need to remove Drc shocks iv done it myself in my garage, there is enough cable length on the Drc system to undo the top nut pull your springs off and replace with the lowering ones
